Hi!
I have been trying to convert a .avi video (PAL widescreen; image size 720x576; duration-01:01:56; file size 13.1GB) video to .mp4 using adobe media encoder CS4 with format set to 'h.264' and preset set to 'PAL DV Widescreen High Quality'. The resultant file is a .mp4 with file size of 1.38Gb. It plays fine on my laptop but this file wont play on my Sony Bravia TV via the USB.
A smaller .mp4 file (duration 00:05:15) created using the same conversion settings plays just fine on the same tv using the same thumb drive.
I have tried setting a lower Target Bitrate to get a smaller file (582mb) but that wont play either. Each time, the TV displays the message - 'Playback not available'.
Somebody please help and tell me what I'm doing wrong. Am I using the wrong container(H.264)? Or is it the TV set?
Other movie files with even 850 mb file size play fine. mkv files around 700 mb in size play without any problems too.
I'd really appreciate help in solving this problem.
Thanks in anticipation..
It's not likely, but maybe the audio is the problem. Did you check to see if the audio is something the TV allows for MP4 files?
Hi Guys!
Glad to state that 'handbrake' did the trick. I can now play a 1.38 GB .mp4 file on the said TV with no problems. Of course handbrake gave the .m4v output file extension which just had to be renamed to .mp4. Thanks Baldrick and thanks to VideoHelp!
By the way, The interlaced video I first tried produced too many noticeable horizontal lines which made viewing awful. I had convert the source video a second time with the 'Fast' option selected under the Deinterlace box in the 'Filters Tab' . Now with the deinterlaced video, things are looking great.
I didn't look into the audio aspects since handbrake did the trick. But thanks usually_quiet.
The region I come from uses the PAL interlaced standard in case anyone's wondering.
Thanks again!Last edited by Keso; 24th Sep 2013 at 14:15.
SONY BRAVIA - 32" LED - Video play back issues from USB port.
By iRecycle in forum DVB / IPTVReplies: 13Last Post: 10th Aug 2013, 03:15 -
Help with getting MKV to MP4 Handbrake conversion to work on Sony Bravia
By crazye2000 in forum Video ConversionReplies: 1Last Post: 20th Jul 2013, 21:48 -
USB flash disk to play 3d on sony bravia
By nickyw1 in forum Newbie / General discussionsReplies: 6Last Post: 2nd Jul 2012, 22:01 -
Sony Bravia KDL26EX320 won't play some files.
By kirk.mufc in forum Newbie / General discussionsReplies: 3Last Post: 29th Aug 2011, 09:08 -
Sony Bravia HD file format
By ksribat in forum Video ConversionReplies: 4Last Post: 29th Jun 2009, 19:58
