Hi. I'm creating a compilation video which is built up of many different individual clips that will be taken from a variety of different DVD's. I've used DVD Decrypter to grab the VOB files from the DVD's onto my hard drive. What I want to do now is go through these files and pick out the clips I need.
Given the number of clips and DVD's involved, and given that the order of the clips in the final compilation isn't set, I'll probably need to slice each clip into its own file to be reimported back into the editor - Sony Vegas - where I can put them all together. Is there an easy way to do this while avoiding any loss of quality? Can VirtualDubMod be used for this?
I know that I will lose quality during the final encoding in Vegas, but I want to limit that loss of quality to as little as possible.
Any advice gratefully received.
Results 1 to 17 of 17
An easy way to do what? Cut chunks out of your VOBs? Yes, MPEG2Cut2, among others apps, can do the cutting with no quality loss at all. It can join all the pieces together later on as well. I don't know why you're using Sony Vegas if all you're doing is cutting and then joining.
I know that I will lose quality during the final encoding in Vegas... -
DVD video is not high quality to begin with. Upscaling it in Vegas would be a vast improvement.
Not to mention all the good utilities in Vegas, like Levels. Just using Levels, Brightness, and Contrast, alone can dramatically improve any video. Try them and see for yourself.
All DVD video is 60 frames interlaced Mpeg2. Any framerate changes are already baked in. No need to do anything special. 16X9 accomodates all aspect ratios. No need to crop anything.
720p is 16X9 and gives you 4X upscale resolution. Perfect. Set your project to 720p and render to 720p and you're all set.
The only exception to easy-peasy is setting anamorphic video to non-square pixels before render. You might have to do those separately, then bring them back in with the rest. You have to bring these back to 16X9 format because they're squeezed into 4:3.
And if I made an error or left anything out, it will get pointed out in the following post(s) below. (just scroll down)
HahahaLast edited by budwzr; 22nd Sep 2013 at 22:54.
- things like creating transitions between clips -
So you can do such things as fades and dissolves between video clips without actually reencoding everything? That's good to know. Thanks. Never made a DVD slideshow myself. I do plenty of fades and dissolves when making 'restorations', but I'm reencoding everything eventually anyway.
Depending on what funkygirl4 is really doing with all her clips, maybe that will be useful to her. I assume you're referring to DVDSlideshowGUI?Last edited by manono; 23rd Sep 2013 at 03:40.
Actually I use Photodex Proshow Gold and I believe (whithout actually making a comparision) that it has more transitional effects than Sony Vegas - as well as effects on the slide itself.
PS Made this in another context. Nothing fancy just an illustration of a transition.
http://www.youtube.com/watch?v=hqUzg8FfVwILast edited by videobruger; 23rd Sep 2013 at 04:38.
Sony Vegas will re-encode in its entirety any mpeg whose structure and encoding proifile doesn't exactly match that of Sony's built-in rendering profiles. Changing color and levels itself means re-encoding. On top of that you're stuck with Sony's Main Concept consumer-be-damned mpeg encoder. Good luck.
Someone said the physical frame size of 16x9 DVD video is changed to 4:3 for encoding. No. 720x480 for DVD (whether the display aspect ratio is 16x9 or not) is not a 4:3 frame, it's 1.5:1 physical frame aspect ratio. DVD is encoded as non-square pixels at either a 4:3 DAR or 16:9 DAR.Last edited by sanlyn; 21st Mar 2014 at 10:43.
Really, just do it in vegas from the original vobs. You're going to have generational loss on effects or anything that doesn't match your main format -- but that's also true of any other workflow you use.
Are there better encoders than mainconcept? Sure. Would you see the difference? Perhaps. Will it take you a lot longer to break out each clip and each transition and each title, separately process them, and then recombine them? You bet. -
So? BFD! You're puttin' lipstick on that pig beforehand to compensate.
No, I said "squeezed".
There's two camps of thought on this subject. The Conservationists, and the Stylists.
I consider DVD material as something from the past generation, worthy of watching, but not worthy of white glove treatment. Ted Turner tried colorizing older B/W stuff to get one more view out of them, but alas, they're finally Gone With The Wind.
If someone had a video of cavemen grunting, now THAT would need white gloves. -
You can only see the "difference" if you view them both side by side, and who's gonna do that?
Of course, as video editors, we notice WAY more things than the average person. And our standard is much higher. We see the faults first, whereas the average person has to be shown.
If you look closely at "Broadcast" video on TV, you'll see a lot of shortcuts and hack jobs in the animation of products. But the average viewer doesn't notice it.Last edited by budwzr; 23rd Sep 2013 at 09:20.
Were you reading this? http://www.slate.com/blogs/quora/2013/09/22/how_complex_was_neanderthal_speech.html
I ran across it over the weekend. -
Is it possible to preserve quality?
By mst in forum Newbie / General discussionsReplies: 7Last Post: 28th Feb 2011, 15:38 -
Is it possible to convert MKV to DVD and preserve 5.1 Dolby sound?
By bija in forum MacReplies: 4Last Post: 28th Jan 2010, 08:10 -
Encoding with higher resolution doesn't preserve quality.
By aznstriker92 in forum Video ConversionReplies: 50Last Post: 2nd Oct 2009, 13:38 -
editing mpg2 to dvd without quality loss
By dailM in forum EditingReplies: 2Last Post: 8th Aug 2009, 01:35 -
Original AVI destroyed. Need to edit MPEG-2 and preserve quality
By neophyte in forum Newbie / General discussionsReplies: 4Last Post: 30th Nov 2008, 17:41
