Hello all,
I updated my codecs with KCP. This codecpack doesn't use ffdshow.
I'm trying to covert 10bit video to 8 bit using format factory. I used to be able to make an avisynth script, load it in format factory and the the frameserver would load the subtitle too. The new encode would have the subtle embedded into it.
Having lav filters i can't find seem to find a way to load the subtitle while encoding. Anyone know a solution for this? Is there a way to use ffdshow only for the subs and only when using format factory?
(xy-)VSFilter is also installed and works when using MPC-HC. But when encoding with Format Factory the subs don't seem to load.
Then verify if Format Factory is or is not using the DirectShow engine for decoding the source video.
VSFilter also includes an Avisynth "interface", so that it can be used as a plugin.
And no, I've never used Format Factory, and I never will ( hopefully
Do I need the LAV filters to play flac files on wmp?
By lascetic in forum Newbie / General discussionsReplies: 12Last Post: 1st May 2013, 13:30 -
Issue with 32-bit portable LAV Filters
By djb247365 in forum Newbie / General discussionsReplies: 0Last Post: 10th Apr 2013, 17:00 -
Potplayer crash with lav filters.
By mzso in forum Software PlayingReplies: 2Last Post: 18th Feb 2013, 22:07 -
Issue with Portable Version of LAV Filters
By djb247365 in forum Software PlayingReplies: 2Last Post: 10th Feb 2013, 16:44 -
Haali Media Splitter, LAV Filters, AV Splitter...How do these filters work?
By Moontrash in forum Software PlayingReplies: 3Last Post: 25th Feb 2012, 19:00
