I have been trying to create a VCD from a DVD with no luck. When using MacMPEG2Decoder, I click the transform button to change the size and the window becomes so big that I can't click ok to close the window. Since I couldn't close it, I went ahead and tried to decode the .m2v and it would only decode the very first picture, the PG-13 screen, which is about 350K. What am I doing wrong?
Try using a different version of MacMPEG2Decoder. (Theres another program out there with a similar name, MacMPEG2Encoder -- make sure you're using the right one.)
There is a setting in the MacMPEG2Decoder preferences to stop encoding at a scene change or something. Tick that OFF! That used to perplex me early on that it's even an option! Who'd want that, anyway?
Vcd audio problems
By Ak_wf1 in forum AudioReplies: 5Last Post: 26th Nov 2011, 20:19 -
Vcd audio problems
By Ak_wf1 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 26th Nov 2011, 19:59 -
Problems with DVD to VCD, including no audio. Help!
By gastrof in forum Newbie / General discussionsReplies: 8Last Post: 4th Jan 2008, 12:39 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Follow up : audio problems with VCD authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jun 2007, 18:34
