I have a VHS tape that was recorded 10 years ago. When playing back (on any machine), it plays back a little too fast. The voices are noticeably too high. Is there some way to convert this to slow it down maybe 10% and lower the voice. I don't want to buy any expensive gear as it is only the one tape.
I think you're attacking this problem from the wrong way potentially, but as most new members do, you have erroneously concluded that by withholding crucial details you are actually making it easier to get help.
What exactly is your goal? To simply play this back on a VCR slower? I don't think that's possible, not without maybe making some mechanical adjustments you may not be up to doing.
If your unstated goal is to actually record this and get it to DVD, then the best approach would be to get it on a PC and fix the audio there. There are free tools like Audacity that could fix this problem easily. I'm guessing that if the playback slowed down 10% you'd also have issues with the video being too slow, but again, your post is skimpy on exactly what you want to accomplish and what hardware/software you have to accomplish your goal, so all we can do is make guesses. -
The video appears to be too fast as well. I'd be happy if I could make the voices sound more natural (lower pitched), but slowing down the video would be a bonus.
I have captured the VHS video into an MPEG file but the same high pitch effect is there. And I would be happy to just correct the file on the computer. Don't need to worry about the tape. Thanks. -
Yeah, a sample, one with steady movement, would be good. Are you especially sensitive to this sort of thing? A musician perhaps? Do you have perfect pitch?
You might try to borrow a variable transformer and gradually reduce the input voltage from say 115VAC to 100VAC. That would work if the VCR drive motor is AC but probably not if DC. Worth a try. Many "geeks" or hams have one laying around...if you were in the Denver area I'd loan you one.
Slightly OT: Roxio announces VHS capture Device Solution
By terryj in forum MacReplies: 5Last Post: 30th Apr 2012, 23:19 -
How to Change your Voice to another normal Voice
By UmmAddan in forum AudioReplies: 2Last Post: 21st Jul 2011, 17:00 -
Howdy,VHS to DVD and I want edit to get rid of the dross and add voice over
By rabbithutch in forum Newbie / General discussionsReplies: 3Last Post: 15th Apr 2011, 17:12 -
VHS-C playback issue, playback in B&W and distorted/noisy colour.
By jpoel in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2010, 09:36 -
Audio slightly high pitched in any player...
By Guitar3dt in forum AudioReplies: 20Last Post: 26th Nov 2009, 17:24
