Vidcoder is a good program that I use often,but it refuses to open any BR that uses VCI instead of avc codec.
Damn. 3000 posts and you post like a newbie.
Do you have problems with only interlaced VC-1 or only progressive VC-1 or both interlaced and progressive VC-1? Interlaced VC-1 is known to be a problem for a lot of easy encode programs.
What's your desired output?
Come on, man. I've seen your posts here and you know what you are doing. Stop acting like you just got here and give us enough info to go on if you want help. -
OK. Yes, it's well known that 1080i VC-1 is a real bitch to get converted. Since you have finally provided enough to go on, I will have to leave it to others to help as I have only tried to encode interlaced VC-1 through BD-RB and it's hit or miss, mostly miss, with it trying to do it.
Maybe you can open the file in AviSynth and feed it into MeGui if no one has any better ideas. -
As VidCoder uses HandBrake, does Handbrake open the video?
If it does, the problem could be with VidCoder in which case ask on the VidCoder forum: https://vidcoder.codeplex.com/discussions
If it doesn't open the video, ask on the HandBrake forum: https://forum.handbrake.fr/viewforum.php?f=11 -
AVI files won't open in Avidemux
By Ahari in forum Newbie / General discussionsReplies: 28Last Post: 18th Mar 2025, 14:22 -
AG-1980 cassette door won't open
By RonFree in forum Newbie / General discussionsReplies: 8Last Post: 19th Jun 2012, 12:06 -
Pioneer DV-260 won't open
By spiritgumm in forum DVD & Blu-ray PlayersReplies: 0Last Post: 20th Sep 2009, 21:09 -
avidemux won't open a DV .avi file
By BrianK in forum Video ConversionReplies: 2Last Post: 14th Jul 2009, 10:10 -
Ripbot 1.13 won't open
By wulf109 in forum Blu-ray RippingReplies: 2Last Post: 9th Feb 2009, 10:45
