  1. ok things have been going great for me lately with vcds, but the last few times i have tryed to rip a dvd using smart ripper, the video is ripped in spanish!!! can someone please tell me how i can fix this
  2. Member adam's Avatar
    Sep 2000
    Do you mean the audio is in Spanish? Unless you used stream processing then all of the audio channels should be present in the ripped vobs. Which language you get in your encode depends on which channel you pick while frameserving. If your using dvd2avi then in the audio section pick a different stream until you find the English one.
    On some dvds certain parts of the movie, usually the credits, are stored multiple times as angles, one for each language. If you are seeing Spanish credits, for example, then you either ripped the wrong angle or multiple angles. Try re-ripping the dvd and if there are multiple angles then try just selecting the first one.
  3. pick a diff. track in dvd2avi
  4. The language of the country the DVD comes from is usually track 1 in DVD2AVI, for me in UK is English. So if is Spanish DVD then choose diff track from 1.
    Or do stream processing in Smartripper to rip English ( or what u want ) from dvd to ac3 then convert that to wav.
    hth
  5. ok ill try those things, but this doesnt happen with dvd2avi, it happens right after i rip the dvd, after i rip the dvd i always play them in my windoes media player to make sure everything went ok, and when i do it with some videos, it is ripped in spanish, however i ripped another movie last night and everything went good so i think its just certain dvds.
  6. ok fellas i got everything straight, thanks a lot for the help.
  7. I wich that can happen to me,,hey!! can you explain how did you got the audio in spanish???
    I want to copy some dvd's and send to my family in Chile with spanish audio...
    I was using dvd2avi and of I choose track1,the audio get in english,then I choose track2 and came in french,then I went to the other numbers left,but no spanish it all,,do I suppost to use smartripper and make some changes in the audio settings?
    thanks in advance
    Rigo.F
  8. Rigo,
    Maybe your DVD disk only has 2 audio tracks(English,French).Most of
    the DVD's I own only come in those languages.
