So I'm using Freemake Video converter to turn files into Video CD compatible files. I found a guide online that told me what settings to use to make the mpegs VCD compatible, but it isn't working at all. When I try to burn the files to the CD using my ashampoo burning software it tells me that the files are not correctly formatted for video, audio, and general formatting incompatibility.
The settings I'm using are mpeg1 codec, 1150 bitrate, 29.97 fps, mp2 audio at 44100 hz and 256 bitrate.
Anyone have any idea why the files are failing so spectacularly?
What video resolution size did you choose?
In addition, according to Wikipedia, your audio bit rate is too high.
https://en.wikipedia.org/wiki/Video_CDVideo
Video specifications[4]
- Codec: MPEG-1
- Resolution:
- Aspect Ratio:
- Framerate:
- Bitrate: 1,150 kilobits per second
- Rate Control: constant bitrate
Audio specifications[5]
- Codec: MPEG-1 Audio Layer II
- Frequency: 44,100 hertz (44.1 kHz)
- Output: Dual channel or stereo
- Bitrate: 224 kilobits per second
- Rate Control: Constant bitrate
I used 320x240. Even if the audio bitrate was too high the CD player kicked back something about the video not being formatted correctly and general formatting problems as well.
I don't know if this matters or not but I transferred one of the mpegs over to my desktop and re-encoded it in TMPGEnc, and when I went to play it it gave some sort of playback error, saying it might not play correctly. Something about a dump overrun or something like that. It ended up playing ok but odd that it would give that message. -
Making them compliant (which your audio isn't) doesn't make them VCDs. They also have to be authored.
320x240 isn't compatible with anything - not VCD, SVCD, DVD or BD. For VCD you MUST have 352x240 with your frame rate.256 Kbps audio is too high for VCD.
Is Ashampoo even capable of burning VCD? It's not well respected here so few use it. I thought it was DVD software, but I'm too lazy to check and have never used it. -
Is Freemake Video Converter safe to use?
By Maukr in forum Newbie / General discussionsReplies: 54Last Post: 26th Feb 2017, 22:22 -
Freemake Video Converter - two (similar) executables?
By StephanP in forum Newbie / General discussionsReplies: 1Last Post: 25th Apr 2013, 02:19 -
Problems with M2ts files converted using Freemake video converter
By jbitakis in forum Video ConversionReplies: 6Last Post: 29th Nov 2012, 12:46 -
Adding Subtitles with Freemake Video Converter
By soshipurpleskies in forum SubtitleReplies: 2Last Post: 22nd Jul 2012, 14:10 -
freemake video converter mp4 to mkv
By rushy7 in forum Video ConversionReplies: 13Last Post: 12th Mar 2012, 13:11
