i have a m2ts file when played 2 sounds come at same time anyway how ican remove the russian and and only put the english audio.thanks
Closed Thread
Use tsMuxeR (or a gui for tsMuxeR called ClownBD) to open the m2ts file. It will show the audio streams present in the m2ts file and allow you to choose which one you want to keep.
Output as an m2ts file.
This assumes that the audio is divided into two separate streams and is not jumbled up together in one. If they have been mixed, then you will have to find another source for audio or hope that it each language is a separate channel and you can get one out using Audacity.
Seems like this is a crosspost...you have more answers in the other one: https://forum.videohelp.com/threads/358963-m2t-audio-removal-please-help
harihack01, Do not post the same topic on several forums.
Please do not cross post, once is enough.
Continue in: https://forum.videohelp.com/threads/358963-m2t-audio-removal-please-help
Moderator redwudz
Can I go from M2ts to M2ts & just decrease the resolution
By jbitakis in forum Video ConversionReplies: 44Last Post: 9th Dec 2012, 08:59 -
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 23rd Jan 2011, 23:28 -
mux m2ts to m2ts with AC3 audio without reencoding the video
By BirdDaddie in forum Video ConversionReplies: 3Last Post: 22nd Aug 2010, 21:19 -
Audio 3 seconds off when converting to m2ts
By trimicada in forum Newbie / General discussionsReplies: 1Last Post: 20th Oct 2009, 14:25 -
No audio with .m2ts in PowerDVD8 Ultra
By vwgolfman in forum Software PlayingReplies: 2Last Post: 27th Feb 2009, 15:17
