Results 1 to 11 of 11
  1. I have Media player classic home cinema 1.6.4.6052 and my problem is that when opening some mkv files like the ones in the pictures i attach, the movie covers only a small part of the screen. Any ideas why this happens? My monitor is a Dell U2412M with resolution 1920x1200.
    Oct 2005
    666th portal
    you'd have to look at the video's stats to see if they're encoded with black bars all around. try mediainfo in text mode. if they show as 1920x1080 but play like that you are out of luck.
  3. View (or right click) -> Video Frame -> Touch Window From Inside
  4. Banned
    Freedonia
    Possibly you have a widescreen source, probably TV, encoded in a 4:3 window. That may not be the case, but if that's what you have, it would look like that.
  5. I did what jabago wrote and it worked. The movie fills the whole screen. Do you know what this option really affects?
    And a last question: I have the zip portable version of MPC-HC (not the installer). Is there a way to save in a file all the changes i have made in the View-Options tab and generally in the settings, so i can apply them in a future version?
  6. Originally Posted by infini View Post
    It controls whether or not the picture is resized to fill the window/screen, or stays a fixed size. It works in conjunction with the aspect ratio settings. The video is scaled up until it fills the width or height, whichever happens first. So if the video doesn't match the aspect ratio of your window/screen it will be letterboxed or pillarboxed. Touch Window From Outside scales the video up until it fills both the width and height of the window/screen. If the video doesn't match aspect ratio of the screen it will be cropped.
    It remembers the setting in the Registry. So you could export the Registry key.
  7. I wish they had an ini file, it would be much easier. Do you know which is exactly the registry key? I ask because since it is the portable zip version i don't think it writes something in the registry.
  8. You must create a text file with the following content:
    [Settings]
    and save next to mpc-hc executable with the file name mpc-hc.ini or mpc-hc64.ini for the 64-bit version
    And check "Store settings to .ini file" in player settings
  9. DECEASED
    Jun 2009
    Heaven
    But MPC-HC does have a checkbox which says "Store settings to INI file"
    Unless things have changed very much between version 1.6.8.7391 and their latest release...
  10. Do you know in which option is this tab?
  11. Oh, I hadn't noticed before but on the Miscellaneous tab there is a Settings Management with Export options (creates .REG files which you can import). The INI file settings is on the Player tab, in the Other box, "Store Settings to .ini file".
