Hi guys. I need help to buy a good hdmi capture card.
I have an AVERMEDIA H727, which is good, but when I am watching football games in HD there's seems to be a little lag on the image. Not so good has the tv box signal.
Can you advise me a good card to buy, without spending a lot of money?
Cheers
Can you outline what it is you're trying to do including sources, resolutions? It sounds like you're wanting to watch the HDMI signal through your computer rather than capture. What do you mean by lag?
Have you tried AmaRecTV's deinterlacing? -
Hi.
Perhaps "lag" is not the better word to describe. When the video has rapid movements (football always has) the image loses quality in those moments. Slow images, the quality is perfect.
When I watch directly or capture in order to stream, it has the same problem. The final objective is to stream. -
I think what you're describing is the effect of the blend deinterlacing done by the included software, which is why I recommended that third-party option.
Elgato Game Capture HD is awesome, A little pricey but def worth it for sure
Hdmi capture card for the system?
By michael_j in forum Capturing and VCRReplies: 3Last Post: 18th Mar 2014, 09:05 -
1080p60 8 audio channels HDMI capture card
By stereoactivo in forum Capturing and VCRReplies: 7Last Post: 6th Mar 2013, 03:24 -
using hdmi splitters with capture card
By TLE6 in forum Capturing and VCRReplies: 1Last Post: 1st Sep 2011, 05:52 -
Good HDMI or Component Capture Card for Game Consoles?
By jargus in forum Capturing and VCRReplies: 18Last Post: 26th Jan 2011, 10:37
