I have an Ati Tv-Wonder pci card. I just got it. Here are my comp specs:
P3 1ghz
192 mb RDRAM
70 GB HD
Geforce 2 Ultra
Here is my problem. I need to capture Tv in Virtualdub. I need it to be at 640 by 480 Resolution. When i try to select that i get an error message that says: Error 418 Unsupported Video Format. I know that this format is supported though because you can do it in Ati's software. Can someone please help me asap. Thanks![]()
Results 1 to 11 of 11
Need more info, what OS are you using and what capture drives are you using?
May the force be with you. -
I had the same problem but in xp. I used generic wmd drivers off the internet. I forgot the url but i know it has the term "soundforge" in it. Now I can capture at any res
Try these drivers that i just found.
http://www.iulab.com/index.shtm?bt8x8/about
i still cant find the other site mate...sorry -
Vdub needs WDM drivers for Win2k and XP
vfw for win 98.
it worked for my ati All in one and vdub.May the force be with you. -
This worked on my ATI TV Wonder VE. If u check the list of compatible TV cards on the web site then in almost 99% sure that it will have ATI TV Wonder (not VE)
Going from high resolution photos to low resolution photos
By bryankendall in forum Newbie / General discussionsReplies: 7Last Post: 5th Jan 2018, 12:57 -
Capturing VHS to PC with a high definition resolution...?
By dark_myuutwo in forum Capturing and VCRReplies: 108Last Post: 10th Jun 2016, 12:18 -
Capturing high-resolution photos from Blu-ray videos?
By Saxkat in forum Blu-ray RippingReplies: 3Last Post: 26th Dec 2009, 09:07 -
High Resolution Monitor on my PC?
By orfajackson in forum Newbie / General discussionsReplies: 9Last Post: 9th Jun 2009, 13:43 -
High Resolution Playback Blocked
By wulf109 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 4th Mar 2008, 08:38
