Hello there.
I have problems with these two softwares because I need to join 13 .asf files in one single file (the files have same sizes and same characteristics)
I downloaded asfbin and installed asfjoin, then I copied the ''asfbin.exe'' file in asfjoin folder, but the program doesn't start! There's a message error that says ''asfcut.exe is not in asfbin directory, you need to install asfbin to use asfjoin''
How I can do this? To my knowledge asfbin is an .exe file so I can not install it!
Please help![]()
I have it, but the resulting file has pauses and loops in the join points... (for example the last second of the first video is repeated at the beginning of the second one, right in the join point where the two files have been joined)
ASFBIN Programs using problems
By jagman in forum Video Streaming DownloadingReplies: 3Last Post: 22nd Oct 2012, 22:48 -
Problem unzipping asfbin download!
By Annette in forum Newbie / General discussionsReplies: 1Last Post: 12th Jul 2011, 12:21 -
Looking for tips on use of ASFbin
By Seeker47 in forum Video ConversionReplies: 0Last Post: 22nd Dec 2010, 11:23 -
ASFBin splitting question
By bartman99 in forum Newbie / General discussionsReplies: 0Last Post: 13th Jul 2010, 11:29 -
Help with ASFBin
By bartman99 in forum EditingReplies: 0Last Post: 13th Jul 2010, 06:17
