Hi allI have an avi file. I load it into script
Then i got info=29.97Code:DirectShowSource("path.avi) info()
So if i load it into script
So the output file of 2 scripts will be same or diffirent?Code:DirectShowSource("path.avi",fps=29.97,convertfps=true)
If the video is 29.97 constant frame rate (which it should be as AVI doesn't support variable frame rate), then the output should be the same.
Note that 29.97 is rounded. The real value is 30000/1001, or 29.97002997002997002997... So there may be a difference in the long run.
WIn7 64, Directshowsource "There is no function named directshowsource" ?!?
By duhmez in forum Video ConversionReplies: 1Last Post: 22nd Jul 2012, 10:28 -
60 FPS avi - question
By pike8 in forum Video ConversionReplies: 10Last Post: 3rd Jan 2011, 16:45 -
Question about FPS/bitrate<->filesize relationship in containers.
By Gew in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2010, 06:19 -
Anime FPS/Interlaced question...
By alcOre in forum Newbie / General discussionsReplies: 6Last Post: 4th Apr 2009, 09:05 -
MeGUI D2V FPS Question...
By alcOre in forum Newbie / General discussionsReplies: 0Last Post: 2nd Nov 2008, 19:52
