Hi,
When I play a clip on the camcorder, the audio is ok; when inserting the SD Card (SDHC I Extreme by ScanDisk) into the slit of the PC as well as connecting to PC via USB cable, there is only noise.
What may be the reason?
Thank you for every hint
Regards
Aloha
Results 1 to 10 of 10
The picture plays and I have tried with different players, one of them being the Magix VideoDeluxe2014 Premium.
How may I check which decoders are installed and if they aren't, how to install AAC or Dolby Digital decoders? -
I have tried now to capture the same scene as MOV and as MP4:_ the problem exists only with the MOV format; the captures in MP4 play with normal sound on the PC.
Hi,
I just tried with Quicktime and the sound is ok, but only with QT.
That is already a progress, but not sufficient because in my editing software (Magix Videodeluxe) the problem exists, too.
What may be the solution? Is there something like a QT codec that I would have to install in order to play the captures with other software than QT?
Sincerely
Aloha -
here is a report. If the information contained in it is not sufficient, I may try tomorrow to upload a short clip.
Playing around with a JVC BR-S525U (or: why I hate DNR)
By Brad in forum Capturing and VCRReplies: 10Last Post: 9th Nov 2014, 19:51 -
high-pitched screeching noise when playing back DVD, but video works...
By xSavant in forum ffmpegX general discussionReplies: 1Last Post: 26th Apr 2010, 18:20 -
Problem playing back JVC miniDV on Panasonic camera
By Ryuran333 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 3rd Feb 2010, 02:16 -
JVC HR-S9800U slowing down going into slow mow while playing tape
By deuce8pro in forum RestorationReplies: 3Last Post: 19th Mar 2009, 17:27
