Hello,
Not sure if I'm in exactly the right forum, but since Video Conversion is what I'm trying to do, hope I'm in the right spot.
After procrastinating for far too long, I am finally copying family VHS tapes onto DVD's. My VCR is a Panasonic PV-V4523S, and my DVD Recorder is a Panasonic DMR-ES15. Don't know their ages, just thankful they work.
Aside from having to watch the 1999 family tape once through, writing down subjects and timings, and then copying them onto DVD's, everything worked fine. I just didn't think it would take so long.
Moving to our 1993 family tape (our oldest one), I find that I am missing a 3-minute section. The tape plays fine for about 20 seconds (from the beginning of the tape) and then I get a blue screen and the tape meter stops. I stop the tape, restart it, and I'll get about a second of what's there, and then we're back to the blue screen. Oddly enough, if I play this tape section and press the FF key, it will show the tape section that doesn't show when played normally, but of course, at a faster speed and without audio.
After about 3 minutes, audio and video resume and play normally for several more minutes before quitting where I stopped recording with this particular tape. The rest of the tape is fuzz, indicating that I had recorded on it but erased it afterwards. I don't need to "unerase" that portion, I just want my 3 minutes near the start of the tape, if possible.
I used several different kinds of tapes back then: Sony, Fujifilm, JVC, whatever. I do not have the VCR camera that I used back then because with 2 small children, I could not afford to buy a camera and had to rent a shoulder-held one from the local video store whenever a birthday or vacation trip came up. Now that my kids are grown and gone, I have 2 video cameras, but do most videos (unplanned) on a smart phone.
Sorry if I have rattled on too long. Any suggestions will be greatly appreciated.
Thanks,
KeyTeacher
An itinerant piano teacher
Sounds like the tape was damaged. Typically, the only way around these type of situations is with different hardware. In this case, that would be a different player. It could be a matter of trial and error to find a player that can actually play the tape. It's entirely possible that it won't play properly all the way through in any player or if it is even playable at all. But there isn't a way to force the current player to play it.
Google is your Friend -
Play it to where it drops out, then eject the tape. Push the little button and raise the door and you will likely see the tape damage. Don't touch the tape surface with your fingers.
If it's narrowed down, folded, or missing oxide, not really much you can do.
You could try a professional recovery company but it's not going to cheap if they can do anything.
And welcome to our forums.
Old VHS Tape Problem
By iris123 in forum RestorationReplies: 1Last Post: 10th Aug 2013, 21:20 -
Convert old VHS Tape to DVD
By ebenton in forum Newbie / General discussionsReplies: 3Last Post: 2nd Dec 2012, 19:56 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
Problem converting from digital8 PAL tape to NTSC DVD recorder
By 1234567 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 27th Jul 2011, 19:01 -
Help! VHS tape suddenlt decided to stop playing. Some sort of configuration problem..
By stevie P in forum Newbie / General discussionsReplies: 4Last Post: 10th Feb 2010, 14:24
