Yeah, someone's still encoding mpeg2. I'm using avisynth to serve cce sp3. I get excellent speeds with everything except a HD xvid source. I can't use directshowsource (which would utilize ffdshow) for a xvid source with cce sp3, even though the script will load without issue in virtualdub. I can use avisource along with the xvid codec, but it's about half the speed and that's with all post-processing disabled. Has anyone found an alternate way to load a xvid clip into cce sp3 utilizing a faster decoder?
About half the speed as compared to what?
I actually encode a lot of HD video, but it's generally avc video, and coreavc provides excellent speed. I average 75-90fps encoding from a 1080p source with that combo. HD xvid source is noticeably slower at the same resolution. It takes longer to re-encode a xvid 720p than a 1080p avc.
LWLibavVideoSource and ffvideosource might be faster.
Haven't heard of LWLibavVideoSource. I'll give that a try. Thanks! -
Let's be honest. While I'm certain that this would never apply to you Genaugmen, the fact is that CCE is out of the price range of most people, so they, uh, find "demo" (wink wink) versions through various means. If a person wasn't married to CCE because he paid a ton for it, perhaps said person would give HCenc (it's free) a try and see if he preferred that and felt that it was better and perhaps faster than CCE. But that advice is for others who read this and not you as I'm sure you are married to CCE because you bought it.
I'm not so much married to cce, but if I push the right buttons, she treats me right. And I haven't achieved the same quality and speed with anything else. HCenc may be the one encoder I haven't tried, but I do remember looking into it not too long ago. I'm not opposed to having a mistress on the side though.
Cinema Craft Encoder Sp 2.67.00.27
By Gwar in forum Video ConversionReplies: 1Last Post: 19th Feb 2012, 12:32 -
Problem with Cinema Craft Encoder SP and Windows 7
By echo1434 in forum Video ConversionReplies: 6Last Post: 24th Dec 2011, 17:51 -
CCE-SP3 to pre-process deinterlace or not?
By Toastie in forum Video ConversionReplies: 1Last Post: 24th Aug 2011, 02:05 -
Cinema Craft Encoder Picture Quality
By pboong in forum Video ConversionReplies: 5Last Post: 24th Aug 2010, 00:17 -
Cinema Craft Encoder Issues converting to 16:9 etc.
By lapetite_66 in forum Newbie / General discussionsReplies: 11Last Post: 8th Mar 2010, 21:09
