I'm new at all, so I'm interested in the followingHow to resize bluray example 47gb to 23.7gb and how to add subtitle and burn bd ,but i like to minimal losse in quality.
Please hel me.
There is nothing I know in the BluRay world that works like MuxMan+VOBBlanker does in DVDs to add subtitles so unless someone knows differently, you will have to reauthor the BluRay to add the subtitles.
Maybe rip the original blu ray as an mkv with MakeMkv, add the subtitle to the mkv with mkvmergegui, then import into BD Rebuilder to compress and make the blu ray output?
This might work, but Stefajdov should realize that if he does this, he will lose the original menus and all extras. But if he only wants the movie, this is a good idea to try.
I say "might work" because I have never done it so I can't guarantee it will work, but I think the chance of it working is very good. -
Keep at least one subtitle in BD_RB. When it starts to mux, abort. Rename your PGS sub to match the one in the work folder. Replace the one in the work folder with yours. Resume the process. No guarantees but it should work. Note that if your are doing full disc and/or have more than 1 sub you must make sure you replace the correct one.
pls help add audio to 3d bluray
By dauyeuub in forum Blu-ray RippingReplies: 8Last Post: 7th Feb 2015, 04:29 -
Converting HD-DVD subtitles To BLURAY subtitles
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 7th Sep 2014, 07:15 -
How to add/change Language on a BluRay
By Cilow in forum Authoring (Blu-ray)Replies: 1Last Post: 23rd Sep 2012, 11:13 -
How add a subtitle to a bluray disk and then convert from 50 GB to 25 GB
By siopilos in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Feb 2012, 10:49 -
Partial upconvert of DVD, add black border = Bluray
By HDTV's Frank in forum Authoring (Blu-ray)Replies: 3Last Post: 13th Jun 2011, 02:15
