  1. I made a svcd and cut it but the wierd thing is on my dvd player after it passes the last piece of where I cut where it should end the sound goes away and the video goes about 10 seconds farther than it should
  2. that happens to me too....so i guess u have to deal with it
  3. well what is a good cutter then
  4. it's fine....just make sure to overlap the parts to cover the section w/o audio near the end
  5. what do you mean you mean on next disc have those parts
  6. if your using tmpge to encode your svcds check out sefy's guide and use the source range so you dont have to cut the file.
  7. Yeah def use source range instead.
    If u dont want to encode again then cut/merge with TMPGEnc again but this time end the first part for example at 50:00 mins then start the second part at 49:30 or 49:00 mins.
    hth. 8)
