Coming from kmplayer this is a little annoying. When I go fullscreen and hover over the lower part of the picture I only get the bottom part of the skin to show. Same thing when I hover over the upper part of the video. Is there any way to make both parts of the skin come up at the same time as if it's one?
Also is there any way to enable showing the skin when you hover over the entire video instead of just the bottom and upper parts of the video?
Thank you.
Results 1 to 1 of 1
From AVI to DVD - Upper or Lower Field First problem
By FrankDrebin in forum Authoring (DVD)Replies: 38Last Post: 11th Aug 2013, 17:42 -
show 2 subtitles at once one on the top and one on the bottom in potplayer
By innn in forum SubtitleReplies: 0Last Post: 1st Jul 2012, 11:36 -
Lower field first/upper field first/progressive/de-interlaced?
By John Nada in forum EditingReplies: 7Last Post: 2nd Sep 2011, 04:12 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 16:32 -
what is the meaning of these ? frame based, lower & upper field first.
By khalid81 in forum EditingReplies: 3Last Post: 15th Jun 2009, 12:27
