I have a DVD I burnt on my set-top recorder, but absent-mindedly forgot to add any chapter stops before I burnt it (after I'd already erased the recorder's HDD, of course).
Is there any easy way to take the Video_TS folder and add new chapter stops in a Mac-compatible utility? Would really prefer than to having to convert the file to MPEG and having to re-encode in real time, etc.
Yep.Originally Posted by smrpix
If the original poster has a lot of video projects in the future then the poster could consider buying a copy of windows (could be xp even) and doing the dual boot with bootcamp assuming this is a intel mac.
The cost would be recovered by the ease that comes with the wide range of excellent freeware software for video projects of all types.
Just thought I'd throw that in there.
By the way programs like tmpgenc dvd author can import an existing dvd structure and you can reauthor it from there without further reencoding (assuming it was truly dvd compatible originally).
I would check for any mac dvd authoring program that offers dvd importing. Than you should, in theory, be able to just import the original folder and author anew without destructive reencoding.
Aside from that you would have to demux that dvd folder and reauthor from the beginning. I don't know what tools can demux on the mac. You would have to search the tools section for that or head to google.
Good luck.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
DVD: Can You Add .SRT To A VIDEO_TS Folder/Files?
By SetoTitan in forum SubtitleReplies: 9Last Post: 6th Jan 2018, 07:30 -
How to change single VOB file to VIDEO_TS folder
By skyllasibe in forum Newbie / General discussionsReplies: 10Last Post: 9th Jun 2013, 06:02 -
Wgat would be the proper folder structure to add movie cover to a folder
By VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 20:09 -
Change MKV back to Video_TS folder??
By soundguy15 in forum MacReplies: 21Last Post: 23rd Nov 2011, 20:15 -
How do I remove chapter stops?
By Ronny G in forum Authoring (DVD)Replies: 5Last Post: 9th Apr 2009, 08:42
