Page 1 of 5
1 2 3 ... LastLast
Results 1 to 30 of 144
  1. 1 My DVD + R are brand Philips CMC MAG M01-00, has lately happened some accidents in handling in my dvd discs and causing some scratches on the bottom blue layer disc, I want to know:
    2 The DVD + R is any brand or Philips they have some protection and resistance to scratches? to protect all my data and layer disc reading?
    3 What are the layers responsible for data storage and which layer responsible for reading the DVD + R disc? these layers are protected from scratches?
  2. Banned
    Freedonia
    This fool is a troll. This is NOT a serious post. Get suckered in an respond at your own peril. Look at his other threads like this one https://forum.videohelp.com/threads/358823-DVD-disc-Fungus
    and
    https://forum.videohelp.com/threads/358471-Questions-quality-Philips-DVD-R-CMC-MAG-M01?...51#post2265051
    and you will see that either this guy is the stupidest SOB on the planet or a troll. Either way, whatever you post, he won't listen to it.
  3. I appreciate the help but I'm not troll, that my post is a serious post
    all my other post are of different subjects and now open to clarify this doubt of scratches on discs and ask please help
    1 My DVD + R are brand Philips CMC MAG M01-00, has lately happened some accidents in handling in my dvd discs and Causing some scratches on the bottom blue layer disc, I want to know:
    2 The DVD + R is any brand or Philips They have some protection and resistance to scratches? to protect all my data and layer disc reading?
    3 What are the layers Responsible for data storage and Which layer Responsible for reading the DVD + R disc? these layers are protected from scratches?
    Feb 2004
    Australia
    General info
    Q2 = none, a theory spun by magic fairy's to promote their brand as superior to others.
    Reality = Store between felt sheets in a dark place with very low humidity and they should last years.
    Q3 = Q2 reply of none and the promise's made by those marketing magic fairy's again
    Printed side has data (scratch it and the disc is toast), this printed side is bonded to an polycarbonate layer having a thickness of less than 0.10mm and in 50% of discs produced also includes dye's used by dvd players laser in read mode to determine between cd or dvd is inserted.
    The remaining 2nd polycarbonate layer is thicker, a supporting layer for the flimsy data layer. May include dye's in cheaper brands and can be sanded to remove severe scratch's in the case of data recovery.
    Final note: NOTHING will protect your media except handling and storage with care.
    That is all you need to know about cd / dvd / bluray media construction
  5. Hard coating protects recording surface against scratches and rough handling
    http://www.verbatim.com/prod/optical-media/dvd/archival-grade-gold-dvd-r/ultralife/
    http://www.amazon.com/Verbatim-95355-UltraLife-Archival-50-Disc/dp/B000H3B6EO/
    I don't know if it really makes any difference. I don't think they make them in DVD+R.
    Taiyo Yuden:
    http://www.amazon.com/Taiyo-Yuden-Recording-Protection-Tapewrap/dp/B001PC0E0I/
  6. thanks for help
    1 I have not scratched the printed side (up disk dvd) I scratched down face that is in contact with the tray dvd burner driver and was wondering if the face down has some protection for small scratches that do not damage the layer and data layer reading
    2 Which layer DVD + R responsible for reading the disc? I know they are 4 layers
  7. Originally Posted by gamemaniaco View Post
    Did you even look at the links I gave you?
    See the diagram at the verbatim link. Or: http://www.cd-info.com/dvd/dvd-plus-r/index.html
  8. thanks help
    1 Yes I saw the links you passed but my disk is not verbatim, my dvd drive is Philips CMC Magnetics
    2 I just want to know: I have not scratched the printed side (up disk dvd) I scratched down face that is in contact with the tray dvd burner driver and was wondering if the face down has some protection for small scratches que's not damage the layer and data layer reading
    3 and also want to know which is the layer responsible for reading the disc and where it is
  9. Originally Posted by gamemaniaco View Post
    If your discs don't claim to have some kind of hardened coating -- they do not.
    I gave you a link which is pretty clear on that.
  10. I read the link but did not quite
    a DVD + R has 4 layers? where are the hidden layers of data and reading? layers read and data are protected by something scratches?
  11. Banned
    Freedonia
    Don't give up now, jagabo. Maybe you two can get this up to 100 posts, especially if Bjs jumps back in to help.
  12. Banned
    New York, US
    ...and ignored advice here and in hundreds of previous posts that the brand is outsourced generic trash to begin with.
    The coating, I don't' know for sure. Verbatim makes DVD+R "AZO", which should have similar coatings.
    I don't know why the O.P. uses DVD+R in the first place. They look like blank discs to some players, which won't accept them. DVD-R is compatible everywhere -- assuming they're not scratched.
    The only type disc I know of that reportedly is built to be more scratch resistant is DVD-RAM (Panasonic, Verbatim). But most players won't handle DVD-RAM.
    I second jman98's sentiments. Now and then it might be good to shout at the wind, if for no other reason than venting might feel better for he who vents.
    Nov 2003
    West Texas
    ^Now you've done it. He'll be asking questions on differences between +R and -R next, and why you think -R is better. Lets just hope no one mentions bitsetting to him.
    Wait a minute...
  14. Member DB83's Avatar
    Jul 2007
    Main difference between +R and -R is that you get a better class of fungus on one.
    Mar 2011
    Nova Scotia, Canada
    I'm having trouble deciding if he's a troll or just an idiot wanting attention.
    Which may be the same thing.
    Either way, he's a moron.
  16. 1 You are distorting the issue and not answering my questions
    2 DVD + R of any brand has 4 layers? where are the hidden layers of data and reading? read layers and data are protected by something scratches?
    3 layer and data layer are reading the label and glossy layer down?
    Oct 2011
    Finland
    A nice find.
  18. I read the review CD and DVD structure but does not say if the DVD + R has some protection for scratches not damage the data layer and the layer of reading
  19. Discs with a hard coating have an additional thin coating outside the polycarbonate layer on the data side of the disc. Most discs do not have that coating, that's why it's not mentioned in the CLIR link.
  20. 1 What is this hard coating? I do not know this, so I know a DVD + R from any manufacturer has 4 layers but I do some scratch protection for the bottom layer of the disc, my disc is scratched only the bottom layer to my hard Philips is manufactured by CMC
    2 also want to know which is the layer responsible for reading the disc, is polycarbonate?
    Oct 2011
    Finland
    My money is on the 100 posts as well.
  22. Banned
    New York, US
    Why stop at 100? We'll get there in no time just by re-posting previous answers the O.P. has ignored.
  23. Banned
    New York, US
    Well, OK, maybe the O.P. has a reason for wanting to know this stuff. I wonder if he has others looking it up for him because he's been banned from Google and Wikipedia?
  24. Originally Posted by gamemaniaco View Post
    Nobody knows. It's a trade secret.
    If you had read the links you would know that they are all responsible for reading the disc. The actual data is held in the dye layer. The reflective layer is required to reflect the laser beam back to the read head. The two polycarbonate layers are required to protect the inner layers and hold everything together. The bottom polycarbonate layer must remain relatively free of scratches in order for the disc to be read.
  25. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    WOW!!!!!
    That is way nicer than what is really required for this person from the shallowest end of the gene pool!!!!!!!
    LOL!!!
    Is he really a "troll" or just more than 20 crayons short of a full box ?!?!?!?
    LMAO!!!!
    I can not believe that this idiot is still posting and what is even MORE amazing, are all the people still replying to his post's!!!!!
    Talk about self-centered and needing to get a life and stop paying attention to worthless waste of time post's instead of thinking they are helping someone who is either beyond help or just trying to jerk everyone around to feed themselves!!!
    He obviously does not, and never will, have a clue or is a serious loser with no life and nothing better to do!!!
  26. Member DB83's Avatar
    Jul 2007
    Talking of 4-layer disks, did anyone ever handle a DVD-18 (or a DVD-14 for that matter) ?
    Phillips must have made some. They made everything else
  27. In closing, just answer me what's on a DVD + R that protects data and the disc from scratches
    1 Layers of polycarbonate are the only protections for scratches on a DVD + R?
    2 The reflective layer is the layer responsible for reading the disc?
    3 how deep of a scratch on the bottom layer that does not affect the reading and the data disk? DVD + R has some tolerance in mm or cm for scratches damaging nothing and reading the data?
  28. Originally Posted by gamemaniaco View Post
    Plastic.
