I am using mencoder to clip avi files, and I have had success in the past, so I think it must have something to do with this particular avi file that I'm trying to clip.
I have an avi file called Movie.avi and I want to clip from starting position 30 and make it 30 seconds long and call it output.avi. So I run this command:
Code:mencoder -ni -ss 30 -endpos 30 Movie.avi -oac copy -ovc copy -o output.avi
And the video that it generates has an issue with the video and the audio being out of sync. The output of the mencoder includes this warning:
Code:Too many video packets in the buffer: (280 in 33600000 bytes).Code:Maybe you are playing a non-interleaved stream/file or the codec failed? For AVI files, try to force non-interleaved mode with the -ni option.
The output also, many times, includes stuff like this:
Code:Skipping frame! Pos: 29.8s 991f (15%) 128.15fps Trem: 0min 693mb A-V:0.067 [28803:0]
And at the very end, the output includes
Code:Video stream: 28771.229 kbit/s (3596403 B/s) size: 108000000 bytes 30.030 secs 998 framesCode:Audio stream: 4373418.000 kbit/s (546677276 B/s) size: 4791968 bytes 0.009 secs
Any ideas about why the audio and video are not in sync. It seems it is off by like a second or so. I ran this commmand to get some details about the file (not sure if this would help).
Code:mplayer "Movie.avi" -identify -frames 0
Here is the output
Code:MPlayer SVN-r35910-4.2.1 (C) 2000-2013 MPlayer Team Playing Movie.avi. libavformat version 54.61.104 (internal) AVI file format detected. AVI: ODML: Building ODML index (1 superindexchunks). AVI_NI: No video stream found. ID_VIDEO_ID=0 libavformat file format detected. ID_VIDEO_ID=0 [lavf] stream 0: video (dvvideo), -vid 0 ID_AUDIO_ID=0 [lavf] stream 1: audio (pcm_s16le), -aid 0 ID_AUDIO_ID=1 [lavf] stream 2: audio (pcm_s16le), -aid 1 VIDEO: [dvsd] 720x480 0bpp 29.970 fps 28771.2 kbps (3512.1 kbyte/s) Load subtitles in ./ ID_FILENAME=Movie.avi ID_DEMUXER=lavf ID_VIDEO_FORMAT=dvsd ID_VIDEO_BITRATE=28771224 ID_VIDEO_WIDTH=720 ID_VIDEO_HEIGHT=480 ID_VIDEO_FPS=29.970 ID_VIDEO_ASPECT=1.3333 ID_AUDIO_FORMAT=1 ID_AUDIO_BITRATE=1024000 ID_AUDIO_RATE=32000 ID_AUDIO_NCH=2 ID_START_TIME=0.00 ID_LENGTH=3556.92 ID_SEEKABLE=1 ID_CHAPTERS=0 ========================================================================= Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family libavcodec version 54.91.102 (internal) Selected video codec: [ffdv] vfm: ffmpeg (FFmpeg DV) ========================================================================= ID_VIDEO_CODEC=ffdv ========================================================================= Opening audio decoder: [pcm] Uncompressed PCM audio decoder AUDIO: 32000 Hz, 2 ch, s16le, 1024.0 kbit/100.00% (ratio: 128000->128000) ID_AUDIO_BITRATE=1024000 ID_AUDIO_RATE=32000 ID_AUDIO_NCH=2 Selected audio codec: [pcm] afm: pcm (Uncompressed PCM) ========================================================================= AO: [coreaudio] 32000Hz 2ch s16le (2 bytes per sample) ID_AUDIO_CODEC=pcm Starting playback... Exiting... (End of file) ID_EXIT=EOF
Results 1 to 12 of 12
Skipping frame!
-> add "-noskip" to your call
I have now tried this commandmencoder -noskip -ss 30 -endpos 5 Movie.avi -oac copy -ovc copy -o Output.avi
And you can see the output here:
pbs-vsg-robertmacbook:Videos Me$ mencoder -noskip -ss 30 -endpos 5 Movie.avi -oac copy -ovc copy -o Output.avi
MEncoder SVN-r35910-4.2.1 (C) 2000-2013 MPlayer Team
success: format: 0 data: 0x0 - 0x5e009c00
[V] filefmt:35 fourcc:0x64737664 size:720x480 fps:29.970 ftime:=0.0334
videocodec: framecopy (720x480 0bpp fourcc=64737664)
audiocodec: framecopy (format=1 chans=2 rate=32000 bits=16 B/s=128000 sample-0)
Writing header...
ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
Writing header...
Pos: 0.7s 21f ( 8%) 0.00fps Trem: 0min 39mb A-V:0.067 [0:0]
Skipping frame!
Pos: 1.0s 31f ( 8%) 0.00fps Trem: 0min 50mb A-V:0.067 [0:0]
Skipping frame!
Pos: 1.3s 41f ( 8%) 0.00fps Trem: 0min 62mb A-V:0.067 [29528:0]
Skipping frame!
Pos: 1.6s 51f ( 8%) 0.00fps Trem: 0min 73mb A-V:0.067 [29383:0]
Skipping frame!
Pos: 1.9s 61f ( 8%) 0.00fps Trem: 0min 85mb A-V:0.067 [29285:0]
Skipping frame!
Pos: 2.2s 71f ( 8%) 0.00fps Trem: 0min 96mb A-V:0.067 [29213:0]
Skipping frame!
Pos: 2.5s 81f ( 8%) 0.00fps Trem: 0min 108mb A-V:0.067 [29160:0]
Skipping frame!
Pos: 2.8s 91f ( 8%) 0.00fps Trem: 0min 119mb A-V:0.067 [29117:0]
Skipping frame!
Pos: 3.1s 101f ( 8%) 0.00fps Trem: 0min 131mb A-V:0.067 [29083:0]
Skipping frame!
Pos: 3.4s 111f ( 8%) 0.00fps Trem: 0min 142mb A-V:0.067 [29056:0]
Skipping frame!
Pos: 3.7s 121f ( 8%) 0.00fps Trem: 0min 153mb A-V:0.067 [29032:0]
Skipping frame!
Pos: 4.0s 131f ( 8%) 0.00fps Trem: 0min 165mb A-V:0.067 [29013:0]
Skipping frame!
Pos: 4.3s 141f ( 8%) 0.00fps Trem: 0min 176mb A-V:0.067 [28996:0]
Skipping frame!
Pos: 4.6s 151f ( 8%) 0.00fps Trem: 0min 188mb A-V:0.067 [28981:0]
Skipping frame!
Pos: 4.9s 161f ( 8%) 0.00fps Trem: 0min 199mb A-V:0.067 [28968:0]
Skipping frame!
Pos: 5.0s 165f ( 8%) 0.00fps Trem: 0min 203mb A-V:0.047 [28964:0]
Writing index...
Writing header...
Video stream: 28771.229 kbit/s (3596403 B/s) size: 18000000 bytes 5.005 secs 165 frames
Audio stream: 4373427.000 kbit/s (546678365 B/s) size: 1191588 bytes 0.002 secs -
a. btw. instead of coloring the output better use the [code]-tags
b. don't remove the '-ni'
c. you also might want to specify the aspect ratio (iirc. '-aspect 4:3' or similar should do this)
d. also try if it helps to specify the output frame rate explicitly "-ofps 29.97" -
Oh, sorry about that, I'll use that tag from now on.
I added in the ni and the aspectratio and the output is identical.
Code:mencoder -noskip -ni -aspect 4:3 -ss 30 -endpos 5 Movie.avi -oac copy -ovc copy -o okay.avi
does the problem also occur, if you:
a. add the output frame rate
b. leave out the range selection "-ss 30 -endpos 5" ?
c. use "-oac pcm" instead of "-oac copy"
d. add "-vfm ffmpeg"
(going to bed now, but these are the 'typical' things I would try)
Cu SelurLast edited by Selur; 13th Sep 2013 at 18:26.
a.
Code:mencoder -noskip -ni -aspect 4:3 -ofps 15 -ss 30 -endpos 5 Movie.avi -oac copy -ovc copy -o okay.avi
b.Code:MEncoder SVN-r35910-4.2.1 (C) 2000-2013 MPlayer Team success: format: 0 data: 0x0 - 0x5e009c00 libavformat version 54.61.104 (internal) AVI file format detected. AVI: ODML: Building ODML index (1 superindexchunks). AVI_NI: No video stream found. libavformat file format detected. [lavf] stream 0: video (dvvideo), -vid 0 [lavf] stream 1: audio (pcm_s16le), -aid 0 [lavf] stream 2: audio (pcm_s16le), -aid 1 VIDEO: [dvsd] 720x480 0bpp 29.970 fps 28771.2 kbps (3512.1 kbyte/s) [V] filefmt:35 fourcc:0x64737664 size:720x480 fps:29.970 ftime:=0.0334 ========================================================================== Opening audio decoder: [pcm] Uncompressed PCM audio decoder AUDIO: 32000 Hz, 2 ch, s16le, 1024.0 kbit/100.00% (ratio: 128000->128000) Selected audio codec: [pcm] afm: pcm (Uncompressed PCM) ========================================================================== videocodec: framecopy (720x480 0bpp fourcc=64737664) audiocodec: framecopy (format=1 chans=2 rate=32000 bits=16 B/s=128000 sample-0) Too many video packets in the buffer: (280 in 33600000 bytes). Maybe you are playing a non-interleaved stream/file or the codec failed? For AVI files, try to force non-interleaved mode with the -ni option. Writing header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. Writing header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. Pos: 2.7s 41f ( 8%) 0.00fps Trem: 0min 64mb A-V:0.133 [14760:0] Skipping frame! Pos: 3.9s 61f ( 8%) 0.00fps Trem: 0min 89mb A-V:0.134 [14644:0] Skipping frame! Pos: 5.0s 78f ( 8%) 0.00fps Trem: 0min 109mb A-V:0.124 [14592:0] Writing index... Writing header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. Video stream: 14400.000 kbit/s (1800000 B/s) size: 9120000 bytes 5.067 secs 78 frames Audio stream: 4373427.000 kbit/s (546678365 B/s) size: 1191588 bytes 0.002 secs
LOTS of output now regarding skipping frames and much more output regarding too many video packets in the buffer. Problem definitely still occurs.
c.Code:mencoder -ss 15 -endpos 5 Movie.avi -oac pcm -ovc copy -o works.avi
This is an imporovement! It shows no frames were skipped and it also shows that both the video and audio stream are 5.000 sec. However, on my Mac, in Finder, when I sit over the Output.avi, the preview thingy just shows a black screen, and the icon for the .avi file is also just a generic quicktime icon and not the image from the actual video. When I, however, open the file in VLC, it works great. But...normally when i use this command, in Finder on my Mac, the little preview is not a black screen but rather the first frame from the video. (Let me know if you want to see a picture of this if you don't have Mac).
d.Code:mencoder -vfm ffmpeg -ss 15 -endpos 5 Movie.avi -oac pcm -ovc copy -o works.avi
Same exact thing as C. Same output (5.000 sec for each audio and video), no skipping frames. However, a black preview which is abnormal for all the other avi files I have. NOTE that I have kept the -oac pcm here. -
After working on this practically all night, I came up with this command that produces the clip correct, with high quality, and with the ability to see it in Finder. Your suggestions helped lead me to this solution, so thank you very much!
The vbitrate comes straight from the mencoder identify frame 0 command.
Just looking for opinions about this. Does this command seem like a standard, good command? Anything weird with it?Code:mencoder -ss 0 -endpos 35 Movie.avi -oac pcm -ovc lavc -lavcopts vcodec=dvvideo:vbitrate=28771224:format=411P -ffourcc dvsd -o works.avi
Batch replace a few seconds of audio clip in .avi or .mkv-files?
By nbarzgar in forum AudioReplies: 9Last Post: 12th Jul 2013, 02:53 -
Combining MP4 files (h264) with mencoder results in blank (white) videos
By mstaker in forum Video ConversionReplies: 0Last Post: 10th Dec 2011, 14:35 -
Avi to DVD and Audio Sync Issue
By macbuz in forum MacReplies: 21Last Post: 11th Jan 2009, 19:04 -
Audio out of Sync on webserver encode using mencoder
By misterio in forum Video ConversionReplies: 2Last Post: 28th Nov 2008, 01:20 -
MKV to AVI, audio sync issue, not on PC, but on HDD media player
By danowat in forum Video ConversionReplies: 1Last Post: 12th Nov 2008, 04:53
