I received some DVD's that I need to edit in a NLE. These DVD's were generated by a dvd camcorder, so the video clips are much more compressed than dv from dv camcorders.
Vegas Pro has native support for dvd camcorders. Vegas can import video from dvd camcorders, without transcoding to intermediate files.
How many lossy compressions there are, in each of the folowing two scenarios:
1. Import DVD into vegas -> export to uncompressed avi from Vegas, using debugmode plugin -> encode to h.264.
2. Decode DVD with DGIndex and compress with Lagarith to make avi intermediate files -> import the avi files into Vegas -> export to uncompressed avi from Vegas, using debugmode plugin -> encode to h.264.
In scenario 1, there are two lossy compressions, and in scenario 2 there is only one lossy compression ? If so, why and how ? Or in both scenarios, there is only one lossy compression ?
Converting from lossy to lossless codec
By sebelk in forum Video ConversionReplies: 8Last Post: 18th Jul 2013, 11:51 -
Lossy 32 bpp (32-bit color) codecs
By videohelperee in forum Video ConversionReplies: 9Last Post: 12th Dec 2011, 21:13 -
Recommendation of Lossy to lossy format(WMV/AVI/MKV to H264) via X264.
By xjohn in forum Video ConversionReplies: 6Last Post: 17th May 2011, 22:27 -
best lossy codec for 320x240 video
By videoasker in forum Video ConversionReplies: 12Last Post: 30th Jan 2010, 12:56 -
help with lossy DRM removal
By kenny1999 in forum Video ConversionReplies: 0Last Post: 7th Oct 2008, 08:22
