hi,
i want to rip some dvds with korean audio and english subtitles(i use makemkv) then re-encode the .mkv i get into a better compressed .mkv file(they are 720x480 and are 4gb+ per dvd).
the subtitles in the dvd are not in any file separated from the .vob files(only files on the dvd are .bup, .ifo, .vob), after i used makemkv to rip the dvd i got 3 .mkv and only 1 subtitle stream(english), when played in vlc these subtitles can be set to disable or select english(or korean if i were to rip that too).
when using mediacoder to re-encode i tried using several subs options but the result is without subtitles. how can i extract or embed the subs to the new re-encoded .mkv the best way, so i keep the perfect text and timers.
i also tried MKVExtractGUI-1.6.4.1Wizard-1.2 but i can't the resulting file is an error, subrip with ocr, but i don't trust the conversion from picture? i suppose to test, and some streams are split into 3-4 .vob files and ripped into 1 .mkv and i'm not sure how to make 1 single subtitle file for them with subrip OCR.
what i want is the re-encoded files to have the original subs text and timers no matter if is hardsub, softsub or .str file, the idea is to be accurate(as the audio is in korean and subs in english no way i can see the mistakes and correct them). i have read a few articles here, thus i tried a few programs, but some gave me errors and i will like a better walkthrough if possible.
ok, details on settings? mediacoder was suppose to do it also, but it fails with no errors and multiple sub settings, i still get the video with no subs.
They never are.
after i used makemkv to rip the dvd i got 3 .mkv and only 1 subtitle stream(english)...
what i want is the re-encoded files to have the original subs text and timers no matter if is hardsub...
Edit Later: I was just checking Hybrid and it can mux the VobSubs, without actually encoding or burning them into the video. Or they can be encoded or 'hardsubbed'.Last edited by manono; 13th Sep 2013 at 03:17.
Split a mkv container
By kyrcy in forum EditingReplies: 1Last Post: 9th Nov 2011, 16:40 -
H264+AC3 (MKV container) to H264+MP3 (MKV container)
By diebri in forum Video ConversionReplies: 3Last Post: 19th Oct 2011, 06:19 -
Adding subtitles to MKV container via mkvtoolnix
By subbin in forum EditingReplies: 1Last Post: 30th Jun 2011, 02:28 -
change an MKV container to AVI container???
By Spdngblt56 in forum Newbie / General discussionsReplies: 10Last Post: 17th May 2010, 21:23 -
converting MKV files in .avi container to dvd
By jamerican in forum MacReplies: 1Last Post: 27th Jan 2009, 10:29
