Can I run multiple ffmpeg instances at the same time?
Or do they confuse each other (e.g. because they use all the same intermediate shared file of a first pass)?
Peter
How do I specify a random unique (!) stats file on the ffmoeg cmdline?
Obviously it should be garantueed that this stats file for ffmpeg encoding no 1 first pass should only be used by ffmpeg encoding no 1 second pass and NOT by ffmpeg encoding no 2 second pass. -
you can't, normally your script (or your manual call) should take of thatHow do I specify a random unique (!) stats file on the ffmoeg cmdline?
most people simply take the name of the input file and attach .stats to it in their script (and delete this file before the 1st pass if it already exists)
Locked MKV files, Multiple Instances of Explorer, PC Lag
By pushkin69 in forum Software PlayingReplies: 3Last Post: 9th Nov 2011, 23:22 -
DirectShow and Drivers--multiple instances of the same capture card
By Austin Covello in forum Newbie / General discussionsReplies: 0Last Post: 7th Feb 2011, 11:43 -
Multiple instances of an actor in same shot, with moving camera
By wildpozzer in forum Capturing and VCRReplies: 4Last Post: 12th Mar 2010, 03:36 -
2 instances of ffmpeg = disk fragmenation
By thodge in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 31st Dec 2008, 13:24 -
Two instances of FFmpeg
By ism33 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 3rd Nov 2008, 16:13
