Manono already hit it. You import the IFO file and let it index the input. You probably already have the standard set to NTSC if you are in the US.
You can certainly try a PAL-->NTSC conversion in this program, but it won't necessarily work well. Its quite a lot to ask of an all-in-one conversion program. Since it can use DGPulldown, you'll have a shot.
If you run into problems, you should start another thread on this particular conversion.
Results 31 to 35 of 35
The PAL to NTSC conversion went OK except the aspect ratio is messed up. It should be 2.37 but the result is somewhere around 3.0. I've asked about it over in the AVStoDVD support thread at:
https://forum.videohelp.com/threads/277852-AVStoDVD-Support-Thread?p=2271173&viewfull=1#post2271173
P.S.
Again, this thread (originally started as a query re DVDFab Creator) has been a very helpful primer for an AVStoDVD newbie with the kind, knowledgable input of Kerry56. Thanks for your help...Last edited by JohnnyBob; 3rd Oct 2013 at 10:59.
DVDFab
By agtjones in forum AudioReplies: 6Last Post: 27th Feb 2014, 16:53 -
DVDFab 8.2.2.6/9.0.2.2
By tarzan54 in forum DVD RippingReplies: 6Last Post: 23rd Jan 2013, 20:16 -
DVDFab 8.1.6.3
By tarzan54 in forum DVD RippingReplies: 3Last Post: 12th Feb 2012, 21:06 -
DVDFab 8.1.3.8
By hardy in forum DVD RippingReplies: 30Last Post: 21st Dec 2011, 04:50 -
Is DVDfab still the best?
By jason in forum Newbie / General discussionsReplies: 38Last Post: 14th Jun 2009, 07:40
