hello!
I just joined this forum. I got a new dv cam here. the model of this thing is : SONY HDR - SR1.
apparently it records direct to a built in hard drive.
my question is: it seems to use HDMI. how do I capture into my system , i probably need an hdmi capture card.
I currently use canon ZR model dv cams for video, and go through firewire (mini to full size firewire) capturing to premiere.
this new thing has hdmi. so i guess i need an hdmi capture card for the system
thanks
mike
There are HDMI capture cards, but for what you want you do not need that. The SR1 is an ancient AVCHD (not DV) Sony camcorder that has a built-in hard drive. The shots you take get captured to this drive. After that you connect the camcorder to the computer via USB; it appears as an external drive, where you can now copy the captured files from.
Since it seems you're new to this, a greater concern would be to identify the files on the camcorder hard drive after capture: folder structure, info files, actual captured files, etc,For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i". -
Most all camcorders with an internal HDD can output via USB. Ones like mine output in H.264 format.
And I changed your title. In the future, please use a title that is descriptive of your subject. I have changed yours this time.
Moderator redwudz
And welcome to our forums.
1080p60 8 audio channels HDMI capture card
By stereoactivo in forum Capturing and VCRReplies: 7Last Post: 6th Mar 2013, 03:24 -
PS3, HDMI Splitter, Video Capture Device or Card, Ambilight, ADVICE!
By NexusSIX1976 in forum Capturing and VCRReplies: 5Last Post: 16th Oct 2011, 20:38 -
using hdmi splitters with capture card
By TLE6 in forum Capturing and VCRReplies: 1Last Post: 1st Sep 2011, 05:52 -
Good HDMI or Component Capture Card for Game Consoles?
By jargus in forum Capturing and VCRReplies: 18Last Post: 26th Jan 2011, 10:37 -
Finding a Good Capture Card For An Xbox 360 System?
By LoC Blood Red in forum Capturing and VCRReplies: 14Last Post: 8th Sep 2010, 22:06
