Currently I have an HTPC connected to a flat panel led tv by hdmi cable. Ive been using it for years and I'm up to 8tb of space. I want to add a bedroom tv. Which makes more sense: buying a tv with dlna or buying a tv and wd tv? I dont know anything about dlna. Will I be able to browse my collection remotely? Does it work with multiple formats? Can I just add a tv with a 1tb hard drive and play by usb? I dont know the capabilities of modern tvs.
I'm not saying you can't stream its just you have more possible limitations with it then a hardware unit. Even more limitations with settop tv/bluray players.
Not saying they don't play stuff its just not as much as a unit like wdtv.
also you'd probably want to get a wifi booster if you have spotty wifi reception in the room you want to go to. No such problem with a direct physical connection.
Also you might look into pricing a used computer to work as a second htpc. You could probably get away with a dual core and a hdmi video card with h264 decoding. But you'd probably want a quad core or better for piece of mind that you won't have stuttering issues.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
It will largely depend on the file types on your HTPC.
Most of the TV and DVD/Blu-Ray based players don't get good reviews. Another option would be a unit such as the Roku 3. I've heard good things about them. But, as noted above, a unit such as the WD would likely have the best support.Google is your Friend -
Originally Posted by krispy kritter
If you go the box route look into a wdtv or possibly a boxee box. Just read the specs and reviews first to know what you are getting into.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Samsung acquired Boxee a few months ago. Boxee products are no longer manufactured, and Boxee's Cloud DVR service was shut down. This probably doesn't mean Boxee Boxes won't work as streaming media playesr, but it is hard to say if access to paid services like Netflix or Vudu will continue to work in the future.
Need DLNA software
By mlong30 in forum Software PlayingReplies: 11Last Post: 1st Mar 2013, 07:07 -
Adding 2nd audio track to specific location...
By tweeker404 in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2011, 23:53 -
Unable to power on the PC after adding 2nd hard drive
By alegator in forum ComputerReplies: 10Last Post: 3rd Apr 2010, 12:57 -
Adding a 2nd Monitor
By Tafflad in forum ComputerReplies: 3Last Post: 4th Feb 2010, 10:11 -
Adding a 2nd audio track to established videos
By madison13 in forum Newbie / General discussionsReplies: 4Last Post: 8th Feb 2009, 23:39
