Is there a way to install ...
Microsoft MPEG-4 Video Codec V1 and V2
... with out disturbing all the existing codecs?
Advanced Codecs will install that codec (I think) but they say they will unplug all other unnecessary codecs. I don't want to disturb all the existing codecs because I am not sure which codec makes my video play now. I am trying to re-encode the video in the subject codec so it WILL run on other computers.
Thanks!
Bob
Hmm??
I tried encoding with ffdshow under VirtualDub and Handbrake on the first pc and then carried over the files to the 2nd pc. Only the one from Handbrake worked on the 2nd computer. The ffdshow/VirtualDub one shows the video noise again.
I used the option under ffdshow "MS MPEG4 v2".
Why Handbrake works and not VirtualDub/ffdshow not is ... well I would like to keep the videos in avi format.
Thanks!
Bob -
Is this a possible 32bit/64bit os issue? I've only recently setup a computer with win8 64bit and its my first 64bit os. I don't know when I'll encounter issues with the wrong software versions.
Was your "first" pc a 32bit os and the 2nd a 64bit?
If there aren't two versions of ffdshow please disregard this post.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I am using 32bit on both pc's.
I can convert the video to uncompressed or logarith lossless codec and the converted file plays fine... but either noise or blank screen with any other codec I try to convert to.
Here is the mediatab printout from the troublesome video file...
===================== General =====================
Complete name : F:\c\L1EngL2Fra_H1Cm1_Draft\L1EngLeFraH1cm1_captur es_original_1.avi\Gen001-001.avi
Format : AVI
Format info : Audio Video Interleave
File size : 34.3 MB
Duration (ms) : 1mn 19s
Total bitrate : 3 622 Kbps
===================== Video =====================
Format : AVC
Format info : Advanced Video Codec
Format profile : High 4:4:4 Predictive@L3.1
Use of CABAC : Yes
RefFrames : 1 frame
Codec Id : H264
Bitrate : 2 218 Kbps
Width : 568 pixels
Height : 426 pixels
Aspect ratio : 4:3
Framerate : 30.000 fps
Colorimetry : YUV
Colos space : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.306
Stream size : 21.0 MB (61%)
Title : ~temp.avi Video #1
Encoded library : x264 core 1679598476May 4 2010
Encoded library settings : cabac=1 / ref=1 / deblock=0:0:0 / analyse=0x3:0x113 / me=hex / subme=5 / psy=1 / psy_rd=0.0:0.0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=1 / nr=0 / decimate=30 / mbaff=0 / bframes=0 / keyint=250 / keyint_min=1 / scenecut=40 / rc=cqp / mbtree=0 / qp=0
===================== Audio =====================
Format : PCM
Format_Settings_Endianness : Little
Format_Settings_Sign : Signed
Codec Id : 1
Duration (ms) : 1mn 18s
Bitrate mode : Constant
Bitrate : 1 411.2 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Bit depth : 16 bits
Stream size : 13.2 MB (39%)
Interleave duration : 101 ms (3.03 video frames)
Interleave preload : 800 ms
Title : Microsoft Waveform: ~temp001.wav -
If your "computer details" are not outdated, then
https://www.videohelp.com/tools/ASF-Codec
should be what you're looking for (unzip, right-click, install, use in VirtualDub).
{ on Windows Vista and Seven, things are much more convoluted, sadly. } -
The current video uses lossless x264 compression . Another option is to use a player on other computers that doesn't require installed codecs e.g. vlc, mpchc , smplayer etc...
Or if you still want to convert, use a converter that doesn't require installed codecs e.g. ffmpeg based ones like tencoder, winff etc... -
If you want to use the avi container you shouldn't encode to h.264. Avi doesn't support all the features of avc.
As el heggunte mentioned, if your profile is out of date and you're using vista or later, 3rd party codecs are not a good idea anyway. My solution in windows 7 was to use software that had the codec libraries included.
Any downsides to installing K-Lite Codec pack ?
By Digmen1 in forum Software PlayingReplies: 7Last Post: 11th May 2013, 14:42 -
Trouble installing AC3 ACM codec on 64 bit OS
By Teemo in forum AudioReplies: 0Last Post: 30th May 2011, 15:42 -
installing codec locally...
By proxima centauri in forum ProgrammingReplies: 2Last Post: 21st Apr 2010, 08:17 -
How do I use the Xvid codec without really installing it?
By KneeRow in forum Software PlayingReplies: 1Last Post: 18th Apr 2010, 15:27 -
Installing the H.264 codec for use with TV tuner
By MrJacky in forum Capturing and VCRReplies: 30Last Post: 23rd Sep 2009, 07:08
