I really need to use VirtualDub but it's not working.
Whenever I attempt to save as AVI, it reads 1/xxx and never continues. Meanwhile, the estimated time goes through the roof.
I've tried redownloading it but that hasn't helped.
Sometimes it will render 10-15 frames before it stops, and other times if you let it sit for 20 minutes it will continue to frame 2, but then stop again.
I realize it's a very old program, but there isn't anything else I can use.
Results 1 to 10 of 10
Please give more information.
Does this happen with every video source? What is the video source? video and audio codec.
What export settings are you using? Video and audio codecs. -
But did it work with a lower resolution in virtualdub?
If by lower resolution, you mean using the "Resize" filter, then no.
Now, for some reason Sony Vegas refuses to read the MKV file created by Handbrake, so I'm trying to convert it to AVI using VirtualDub.
I am getting an error "Out of memory", which is impossible because I have 16GB of RAM.
EDIT: Yikes, I just can't catch a break..
I'm trying to convert the video using AVIDemux, but I am getting the error "Bitrate too low?"Last edited by Track; 11th Sep 2013 at 05:56.
No, Lagarith is the only one I'm using right now.
I'm mainly interested in resolving these three problems:
1.) VirtualDub stuck on first frame.
2.) VirtualDub "Out of memory" error.
3.) AVIDemux "Bitrate too high?" error.
Should I start another thread?
VirtualDub: incomplete frame. Is it ignorable?
By falco2000 in forum Video ConversionReplies: 35Last Post: 28th Feb 2013, 09:21 -
Virtualdub: Capture frame not working
By terrypin in forum Newbie / General discussionsReplies: 1Last Post: 16th Feb 2013, 03:54 -
Newbie questions about frame rate (also VirtualDub)
By wallywalters in forum Video ConversionReplies: 5Last Post: 29th Oct 2012, 09:16 -
Resizing(Frame Size) w/ VIRTUALDUB - PLEASE HELP!!!
By MDrumm in forum EditingReplies: 8Last Post: 17th Jan 2011, 02:12 -
How do I remove a bad frame from a video without VirtualDub or DivFix?
By teapot in forum Newbie / General discussionsReplies: 7Last Post: 11th Dec 2008, 19:07
