I've been searching and cannot find the answer Im looking for.
I have a movie that I'd like to add another foreign language AC3 audio file to.
The foreign language AC3 is shorter by 1 second and I need to stretch it.
The Foreign Language AC3 audio file is: 01:04:38.368
It needs to be 01:04:39.712
I have tested the number above using MKVmerge it works perfectly. BUT MKVmerge does not re-encode and I want to make a BLURAY so I need to stretch the actual AC3 file. HOW?
Is there a guide or walk-through please.
Thank You.
Results 1 to 10 of 10
AC3 what ?
2 or more channels
Install audacity, then file > preferences > libraries
Hit download mainly for the ffmpeg library and install.
Then edit menu > preferences > import/export, select "use custom mix"
You will be presented with a "channel mapping" option during Export that allows you to select which Audacity track goes to which audio channel in your exported file
Once done you should be able to open the ac3 in audacity ... may take time to load the file
Audio align:
Next in lower right of main screen change "audio position" by clicking the arrow on its right hand side and select hh:mm: ss + milliseconds.
From here in your case and if audio sync is fine, simply copy silence portion equal to 1. 344 seconds and paste into each channel on the end.
Then file > export, name file, hit save and a panel with channel output opens allowing you to set and reorder channels, hit ok and wait.
Enjoy new file. -
Thats not stretching the file.
I need to Stretch the audio file by 1.344 seconds not add 1.344 seconds.
I am not trying to be mean, because you are trying to help, but if you read my original post you will see that if I use stretch by in mkvmerge it works. But MKVmerge does not reencode the audio and i need to stretch and reencode the audio. -
Maybe my math is bad but I work it out as original x 1.00035, or .035% (to within about 10ms).
Audacity has a couple of "Change Speed" effects which seem to allow you to specify a stretch in .001% increments.
There's a DSP for foorbar2000 which can be used while converting called SoundTouch, but it'll only do .01% increments.Last edited by hello_hello; 11th Sep 2013 at 07:34.
Ok cool.
Now how do I get that value.
The Foreign language ac3 is 01:04:38.368
I need to stretch it to 01:04:39.712
Can you please tell me how to get the % value for that.
Also pardon my ignorance, but if you can supply me with a % please show me the steps to get that %.
I realize now its a calculator issue. Got the 2nd part out the way with your help. -
01:04:38.368 = 64 minutes, 38.368 seconds or 3878.368 seconds.
01:04:39.712 = 64 minutes, 39.712 seconds or 3879.712 seconds.
3879.712 / 3878.368 = 1.000346573513
To confirm:
3878.368 x 1.00035 = 3879.725 or
3878.368 x .035 / 100 = 1.357
3878.368 + 1.357 = 3879.725 (13ms out due to rounding).Last edited by hello_hello; 11th Sep 2013 at 08:07.
Audio stretch using MKVmerge
By zilbermm in forum AudioReplies: 5Last Post: 24th Jul 2013, 05:05 -
MKV to MP4 audio stretch issues!!!
By wphill in forum Video ConversionReplies: 3Last Post: 18th Jul 2012, 07:42 -
Free program to stretch or shrink audio for sync
By silverwolf0 in forum Newbie / General discussionsReplies: 3Last Post: 9th Aug 2011, 21:51 -
MKVmerge - stretch audio
By snadge in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2010, 06:52 -
How to Stretch audio perfectly using cool edit. how to calculate it
By afcoff in forum Video ConversionReplies: 0Last Post: 9th Feb 2009, 05:22
