I recently updates GOM to their current version 2.02 I think. With the old version I was able to set it so that whatever clip or video opened it would open with the same window size and aspect ratio. I don't seem to be able to do that with this update
I don't remember how I did it before but I believe I had to go into a cfg or ini file and hard edit it. I was running the old version on Win XP but now I have Win 7 Ultimate but cannot find where the "default settings" file is stored.
Anyone have any suggestons?
Both can be set in the various preferences settings: http://player.gomlab.com/eng/guide/preference_top.gom
Google is your Friend -
Sorry to bother you... Can you be more specific in your recommendation?The options that I am looking for... to open every file with the same, user defined, window size and aspect ratio ARE NOT in the preferences options in any way that I can find.
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 07:28 -
Gom player and MKVmerge v2.70 and above
By nasdravi in forum Software PlayingReplies: 2Last Post: 9th Jun 2009, 01:42 -
Error Comment on GOM AND MPC Video player with MKV
By cutefix in forum Software PlayingReplies: 21Last Post: 1st Apr 2009, 23:30 -
new abbrev, GOM = GOM Player ?
By lordsmurf in forum FeedbackReplies: 1Last Post: 1st Apr 2009, 15:00 -
Slight problem with GOM Player
By jonghyunchung in forum Software PlayingReplies: 1Last Post: 22nd Oct 2008, 02:04
