Have a movie file that is using ac3 audio but it is so poorly low that it is impossible to watch. Really good movie and wanted to try and raise the gain and correct the volume in virtual dub. It does not find any codecs to open the avi file. the file plays fine in windws player or in vlc which is my default player. How do I tell virtual dub to use the same codecs vlc is using to play the file etc. Or is there another way to correct this audio.
Sad really, what good is ac3 if you can't hear a bloody word people are saying. I am watching on big screen thru a phillips bluray player if that makes any difference or if there is a way to make the correction on that side etc.
I thank you for your attention... over the years this has been the best site out there.....
thanks
the bot
VirtualDub cannot use the same video codecs as VLC because VLC uses it's own built in codecs that no other program can access. Neither can VirtualDub use the same video codecs as WMP because WMP uses DirectShow codecs whereas VirtualDub uses VFW (the older, outdated, deprecated video subsystem in Windows) codecs. So you need a VFW decoder for the codec used in your source video. ffdshow probably has the decoder you need.
Your main problem is most likely the fact that AC3 levels are typically about 20 dB below typical computer audio. Just turn up the gain on your AC3 decoder.
If only the dialog is too low you have a different problem -- your speaker configuration is wrong. You're probably set up for 5.1 speakers but don't have a center channel. -
For 5.1 > 2.0 channels with a mix that increases the volume, I like the directshowsource ffdshow mixer method.
Doesn't take too long to setup, and you can do it in the fly in Virtualdub. -
ok, have obtained and installed ffdshow, how do i use virtualdub and ffdshow together to fix the audio of this avi movie.... has very low ac3 audio which you can't hear the voice very well at all. thanks
don -
If not installed already, install FFDshow, Lame ACM mp3 and Avisynth. (All on this site in tools/software area).
Here's a general walkthrough I did before:
https://forum.videohelp.com/threads/357689-Low-volume-when-loading-external-audio-file-...=1#post2256520
Open the movie in Virtualdub and set video/direct stream copy.
If you'd like PCM/WAV audio, the above instructions will achieve it.
If you'd like to compress the audio to mp3, do these additional steps.
Set audio/full processing (instead of audio/direct stream copy)
audio/compression - select Lame mp3 and configure on the right to one of the higher bitrate CBR modes.
File/ save as avi
Virtual Dub Codecs ?
By lalson639 in forum Video ConversionReplies: 1Last Post: 23rd Mar 2013, 01:40 -
virtual dub reported CPU usage not matching windows reported
By Spektre in forum Capturing and VCRReplies: 0Last Post: 14th Jan 2013, 21:01 -
MTS in Virtual Dub
By Nanley in forum User guidesReplies: 7Last Post: 6th Jul 2012, 05:10 -
Windows 7, Virtual Dub (any Version), BlackMagic Intensity Pro = No Capture
By Digital-Overload in forum Capturing and VCRReplies: 2Last Post: 22nd May 2011, 10:57 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48
