Does anyone know if Sony Vegas 8 Pro will run ok in windows 8
I am buying a new computer and they mainly come with windows 8 pre installed.....
Cannot find a reference to wether or if Vegas 8 pro will run on a new computer with windows 8...
Thanks in advance if anyone has the answer
Let's say it doesn't work, what will you do? Not buy a new computer? May as well try it.
At best you're still going to be very limited as to which types of files will play/edit smoothly.
At worst you upgrade your version of vegas as well. (Or even "downgrade" to $50 Studio Version 12) -
My alternative is to get a new computer with windows 7 ..which vegas 8 pro will work..... and i do not need to upgrade my Vegas 8 pro
The other issue is ... many say they do not like windows 8...but i am still unable to find out if it will run in windows 8 or not..... even google seems to have no defind answer...of yes or no... -
You can always get Win7 with Win8 lincence included,something like this: http://www.microcenter.com/product/415126/ProBook_4540s_156_Laptop_Computer_-_Aluminum
Thanks all for your info........
Will probably go the Windows 7 route
Difference in price between Sony Vegas Pro 11 & Sony Movie Studio Platinum
By Ghost Dust in forum Newbie / General discussionsReplies: 8Last Post: 11th Feb 2013, 12:42 -
Sony Vegas Pro 9.0e running under Windows 7
By mltwitz in forum Newbie / General discussionsReplies: 1Last Post: 16th Aug 2010, 15:43 -
Does anyone know if Vegas Pro 8.1 will work with windows 7?
By ingeborgdot in forum EditingReplies: 2Last Post: 11th Nov 2009, 20:30 -
Sony Vegas Pro 8
By Jules2 in forum Newbie / General discussionsReplies: 6Last Post: 2nd Mar 2009, 19:59 -
Sony Vegas Pro
By Liquid9Kitty in forum EditingReplies: 2Last Post: 15th Feb 2009, 02:53
