  1. Hi,
    I have a .ts file which generate by a PVR(personal vedio recording unit). but i can't view through my pc.
    I think these files are encrypted. Is there any way convert these files.
    Need help .
    Thank
    Jas
  2. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Post the mediaInfo log of the file. Re encryption what country are you located - makes a difference some countries don't encrypt whilst others do, also make of your PVR - ditto last comment.
  3. I am located @ Sri Lanka.
  4. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    OK you need to find out if it is part of Sri Lankan digital tv standard to encrypt and/or your PVR model. Still the best way to resolve this is to post a MediaInfo report (in tree text mode).
  5. Thank for the information. I have install the SW.
    General
    Complete name : H:\DVR005.TS
    Format : MPEG-TS
    File size : 50.6 MiB
    Menu
    Menu ID : 10 (0xA)
    List : 1402 (0x57A) () / 1403 (0x57B) ()
    how can i extract the file.
    thanks
