Please help!!!! I've Been backing up my dvds for about a year now and I have a tried and try method with very good quality vcds but still haven't got a clue on how to get the tiny clusters out of my finished vcd.. when I play them in my Philips DVD711 stand alone player every so often I will get a little cluster that comes up on the tv. I have used every cdr ther is and clean ones too I even cleaned the dvd player They are only for about a millisecond but it is anoying as hell.... I am now using a AMD 1400 with 512md 2100ddr but that still didnt solve the problem still the same as when I used AMD 900 w/sd ram. What I am doing is ripping w/smart ripper then encoding w/flask amd w/panisonic premire plugin at 240x352 with a video bit at 1246 and audio at 128 then chopping it in half w/tmpge then burning it w/nero 5.5 and what I get is a great vcd with hardly any digaztation and fantasic sound But like I said every so often ethier I get a milisecond pause or I get a little white cluster..... any help would be wonderfull....
Also another problem is some of the vcds I have done play great on my 300mhz 64mb laptop but some play very slow when I check my cpu status ont the ones that play slow it's maxed out at 100 percent any ideas it only has a 24x cd rom but even when I copy the dat files to the hard drive it's still the same... Think more memory will do the trick.... Or could the high video bitrate be causing this?
Thanks,
Framerate![]()
Results 1 to 1 of 1
bad sectors/clusters
By stompinne in forum Authoring (DVD)Replies: 7Last Post: 17th Sep 2008, 15:13
