hii use one-click endoer to encode my movies but i need to encode whit bitrate not size
what do i have to do?
Use an online bit rate calculator to decide what bit rate you need for the size you want.
I'll dust off the crystal ball and assume you're referring to MeGUI's one click encoder?
Either,
Use MeGUI's x264 encoder configuration to set up a configuration for 2 pass encoding at the required bitrate, save it as a preset and select it as the x264 encoder preset One-Click will use,
or
Work out the file size required to achieve the desired bitrate and use that file size when setting up a One-Click encode.
Under the Tools menu you'll find MeGUI's bitrate calculator. Enter the duration and desired bitrate, and if your One-Click encode will also include audio, add it to the bitrate calculator too. If the audio is to be re-encoded, enter the bitrate you'll be using when re-encoding the audio instead. The calculator will then tell you the file size to use for your One-Click encode.
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 09:13 -
How to add to the Right Click Dropdown Menu
By jollyjohn in forum ComputerReplies: 6Last Post: 13th Apr 2011, 21:59 -
How can I cut/edit/merge/add some info/add hardsubtitle in one media (DVD)?
By roUndy_sh in forum EditingReplies: 8Last Post: 26th Dec 2010, 17:45 -
SVCD 2 DVD Not Working - Cant Add VTS or Click Convert
By rytech in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 2nd Feb 2010, 03:55
