Hi, i dont understand whats going on.Im encoding a movie at CRF @ 14, when it starts encodeing the FPS is above 60, but after like 2 mins to drops to like 11 FPS....WHYYYY is that? is it a encode proeblem(x264) or is it my cpu(no likely).
Also im not riunning anything demanding in the background while the encoder is encoding
Plz help
	I'm using both Handbrake and XviD4PSP and in both cases I also start out strong, well over 60 fps but that declines as it progresses.
 I left my laptop on last night and set power management to none. I set up a batch in Handbrake. I had 4 mkv files to encode and when I went to bed at 1:00 AM I was at 75fps. I figured all 4 movies would complete in a couple of hours and I'd be done. When I came back in the morning at 7:00, only one had completed and my FPS was down to 7.
 I waited 2 more hours for the second to complete and then ended it.
 Then I put one movie in Xvid4PSP and ran it to see if it would work better than handbrake. Again I started around 70Fps but now as I'm 87% complete I have declined all the way to 6.5 fps.
 My task manager shows XviD$PSP at around 30% and ax264.exe at about 40%.
 Any ideas?
	Some frames compresses faster than others. For example, totally black frames compress much more quickly than highly detailed moving shots. Movies often start with a fade from black, static logos, and static titles. So it's not unusual for the frame rate to drop once the actual movie starts. Your drop from 75 fps to 7 fps does seem excessive though.
 How does CPU usage compare when starting and later when slowed? What about memory usage?
	And what is the CPU speed and temps both starting and when slowed? Overheating and CPU throttling might be another possiblilty, especially on a laptop. Not all power management settings are necessarily accessible through the OS (You might have to go into the BIOS)
 Also, were you using 1pass CRF encoding ?
 The OP was using CRF encoding (I'm assuming 1pass) , but if you're using multipass encoding , the 1st pass is usually much faster (as an analysis pass) unless you specifically specify --slow-firstpass settings . So with multipass encoding your observations might be "normal" depending on the settings usedLast edited by poisondeathray; 20th Oct 2013 at 19:09.
	I just booted to my BIOS and I didn't see any power management options in there. I'll check my power profile to make sure it's not throttling the CPU. *UPDATE I don't see anything that throttles my CPU in the power management. Last edited by swing4thefence; 21st Oct 2013 at 01:22.
	Just looked at your profile:
 Overheating, CPU throttling.AMD FX-8150 8 Core OC - 4.7 ghz
  Cut A Video without losing quality in x264By kaaviyan in forum EditingReplies: 5Last Post: 27th Jan 2013, 13:06
  video conversion and fps drop out in Adobe Premiere Pro.By shh1cd in forum Video ConversionReplies: 6Last Post: 6th May 2012, 01:17
  HDV Video >>>>> Use Non drop frame or drop frame and why?By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 3rd Nov 2010, 19:30
  Epic thread: Anime MKV files to MP4 for iPad.By Syn3rgetic in forum MacReplies: 15Last Post: 3rd Aug 2010, 23:05
  WinFF Epic failureBy b8375629 in forum Video ConversionReplies: 33Last Post: 25th Jul 2010, 06:42
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
