Tried my first capture with ATI 600 USB off a JVC SR-S365U with virtualdub huffyuv. I created a 30 gig 720x480 29.97 PCM 48k audio. On a 1 hour tape about 30 minutes into it I experienced the chipmunks audio which last throughout till the end of the video. Also the video thorughout does not seem smooth and kind of jumpy. At the end of the capture virtual dub showed a bunch of dropped frames. Any suggestions on what can be done?
Results 1 to 11 of 11
1 - Switch HUFFYUV to UT VIDEO CODEC ULY 2.
2 - Uncheck ENABLE AUDIO PLAYBACK in Audio tab.
3 - Make changes in Capture tab, Timming. Sometimes its help various users when capture from USB device.
4 - Disable PREVIEW in Video tab.
Try & reply.
Claudio -
#2 may help with dropped frames
#3 Set: Do Not Resync Between Audio and Video Streams -
thanks for the quick replies. will try again with suggestions and report back..
Similar problem with ATI 750 USB, solved with DVD recorder passthrough:
https://forum.videohelp.com/threads/358224-VirtualDub-Capture-Issues-with-ATI-TV-Wonder-750-USB -
x22, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz
VirtualDub Capture Issues with ATI TV Wonder 750 USB
By cbehr91 in forum Capturing and VCRReplies: 18Last Post: 2nd Sep 2013, 12:56 -
Capture software for ATI HD Wonder 600 PCIe
By Spektre in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2011, 09:31 -
Ati 600 usb stick and virtualdub capture
By buckethead in forum Capturing and VCRReplies: 4Last Post: 8th Mar 2011, 17:13 -
Diamond ATI Tv Wonder 750 USB and virtualdub
By buckethead in forum Capturing and VCRReplies: 9Last Post: 31st Jul 2010, 04:34 -
window media encoder 9 and Diamond Multimedia ATI TV Wonder HD 600 USB 2.0
By nick7920 in forum Video Streaming DownloadingReplies: 1Last Post: 1st Oct 2008, 17:52
