Basically, I'm getting dropped frames at no more than 27% GPU load, and ~10% CPU Load.
What I did: Installed KLCP 10, and ReClock. Followed this guide for Highest settings. Played video with this MediaInfo:
The resolution is 1920x1080Code:Format : AVI Format/Info : Audio Video Interleave File size : 550 MiB Duration : 52mn 32s Overall bit rate : 1 463 Kbps Writing application : Some super fast AVI muxer Video ID : 0 Format : MPEG-4 Visual Format profile : Advanced Simple@L5 Format settings, BVOP : 2 Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Codec ID : XVID Codec ID/Hint : XviD Duration : 52mn 32s Bit rate : 1 305 Kbps Width : 624 pixels Height : 352 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.248 Stream size : 490 MiB (89%) Writing library : XviD 70 Audio ID : 1 Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Codec ID : 55 Codec ID/Hint : MP3 Duration : 52mn 32s Bit rate mode : Constant Bit rate : 32.0 Kbps Channel count : 2 channels Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 54.9 MiB (10%) Alignment : Aligned on interleaves Interleave, duration : 24 ms (0.58 video frame) Interleave, preload duration : 10 ms Writing library : LAME3.97
Specs:
- Mobo: GigaByte GA-H67MA-UD2H-B3
- Processor: Core i5-2400 @ 3.1 GHz
- Memory: 4 GB DDR3 Corsair Value Select @ 1333 MHz
- GPU: nVidia GeForce GTX 680 (Reference Design)
- HDD: Seagate 2 TB (64 MB cache)
- PSU: Some Cooler Master one, 600 W (don't know exact model)
Results 1 to 1 of 1
Virtualdub dropped frames
By TB Player in forum Capturing and VCRReplies: 16Last Post: 9th Jul 2013, 12:48 -
Thousands of dropped frames!! :O
By ChibiBoi in forum Capturing and VCRReplies: 29Last Post: 4th Feb 2013, 14:40 -
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33 -
Dropped Frames
By SudsMalone in forum Capturing and VCRReplies: 4Last Post: 21st Feb 2011, 05:31 -
You Get dropped frames? That's for you
By themaster1 in forum Capturing and VCRReplies: 2Last Post: 6th Dec 2009, 22:21
