Sorry! my english is bad!
How to compress avc1 video with minimal cost?I have OBS + quick sync -> 2nd computer -> rtmp server -> ffmpeg -> twitch
So, I need to compress from 10 000k video to 3 000 k at minimal cost...
After OBS:
Video #2
Format : AVC
Format profile : High@L3.2
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Muxing mode : Container profile=High@3.1
Codec ID : avc1
Duration : 6s 250ms
Source duration : 6s 225ms
Bit rate mode : Constant
Bit rate : 9 200 Kbps
Nominal bit rate : 10 000 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 60.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.250
I need to compress it to 3000kbps. What should i do?
Re-stream whithout compression ->20% cpu
ffmpeg -re -i "rtmp://xxxx" -f flv rtmp://twitch
only with -c copy it works without cpu utilization
ffmpeg -re -i "rtmp://xxxx live=1" -c:a copy -c:v copy -f flv rtmp://twitch
I'm using this to compress, but maybe it's not best solution.....
ffmpeg -re -i "rtmp://xxxx live=1" -c:a copy -crf 25 -preset veryfast -vcodec libx264 -b:v 3000k -maxrate 3000k -bufsize 3000k -f flv rtmp://xxxx
Please, ANY help is welcome. Thank you!
Results 1 to 10 of 10
"at minimal cost..." = minimal encoding time, then enable:
a. preset ultrafast
b. tune zerolatency -
Problem there is that I don't know of any encoder/tool which offers:
a. support for input via pipe (or can capture rtmp streams)
b. support for QuickSync/CUDA/OpenCL (de- and) encoding
c. can passthrough audio
d. can output to flv
so not all hope is lost, but I wouldn't hold my breath.
-> aside from writing your own application based on ffmpegs rtmp input code, some QuickSync-/CUDA-/OpenCL-SDK and ffmpegs flv muxing code; the normal ffmpeg seems to be your best choice. -
Thx for your help! And one more qustion. How can i convert rtmp to directshow and then import in OBS ( OBS support openCL)?
iirc there are some rtmp DirectShowFilter out there which allow you to grap rtmp stream through directshow, but no clue how to use OBS with that.
Don't know. http://www.techarp.com/showarticle.aspx?artno=669 might help a bit, normally x264 itself scales nearly linear (in core count and clock rate), but the input speed might still be limited by the hdd, the decoder,....
Where to get the AVC1 codec to play .mp4 videos?
By TyLord in forum Newbie / General discussionsReplies: 27Last Post: 29th Nov 2013, 05:11 -
Cannot display or convert video that uses AVC1 codec?
By peggypwr1 in forum Newbie / General discussionsReplies: 12Last Post: 4th May 2011, 04:19 -
How to Extract - Syncronize AVC1 - DSH Files?
By devilcoelhodog in forum Video Streaming DownloadingReplies: 6Last Post: 12th Jun 2010, 10:49 -
AVC1 to MP4 playback speed too fast
By Cathedralcat in forum Newbie / General discussionsReplies: 3Last Post: 6th May 2010, 22:41 -
No AVC1 avi playback in quicktime
By roper in forum MacReplies: 6Last Post: 11th Nov 2008, 13:42
