So I can find an encode of a movie at 1280x528 and a different encode of the same movie at 1280x544 and then compare them frame by frame.
It looks like either the 528 is slightly squashed vertically or the 544 is slightly stretched vertically. I would think the original AR would be maintained and the differences are just differences in cropping the black bars, but with the 544 people have noticeably longer foreheads
Is it that my vlc is badly setup or is the original AR not maintained when encoding a bluray as x264 720p, resulting in either slight squashing or stretching?
It's more likely the A/R is sightly out on one of them. Often you see dimensions a factor of 16, sometimes rounded up,
sometimes down.
On the otherhand, there could be an overriding display aspect ratio, which some (most?) video players will honor.
You can find out by looking at the file details in mediainfo -
What program are you using to re-encode to blu-ray compliant files?Is the display aspect wrong when playing on a blu-ray player or just on your computer?
Resizing 1280x544 to 1280x720 Problem,Please HELP!
By rockprince in forum Video ConversionReplies: 11Last Post: 13th Apr 2012, 12:18 -
What's the BEST way to convert HD .m2ts (720p) to a HD .mp4 file (720p)??
By elgy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Jan 2011, 19:03 -
1280x544 to 1280x720 for letterboxed avchd with multiavchd - confused
By yoda313 in forum Video ConversionReplies: 12Last Post: 22nd Oct 2010, 13:40 -
2 x 720p AVI with DTS - need 1 x 720p MKV with AC3
By snadge in forum Video ConversionReplies: 2Last Post: 25th Oct 2009, 12:38 -
UNDERWATER VIDEO - Should I get a still-cam with 720p, or a 720p camcorder?
By v1ru5 in forum Newbie / General discussionsReplies: 1Last Post: 25th Aug 2009, 02:49
