This is a new one for me, got a film ending in .bin and .cue can these be burnt as a VCD.
Sorry if this is a dumb question but as I saud these file types are new to me.
Originally Posted by Smudge249
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
fireburner is an excellent program to burn images and .bin, .cue files....
goto www.fireburner.com to download a trial version of it...you can PM me and i'll give you registration code for it -
sorry poopyhead can't stand fireburner (from old psx days)lol
cdrwin in my exp is best for burning bin/cue. Load cue and click start, thats it.
HTH -
Or if you want to go freeware, use VCDEasy, which includes a tool for burning bin/cue images (Tools>CDRDAO Tools).
Nero doesn't burn bin/cue images correctly, btw, as has previously been explained in this forum, so I'd stay away from it for this purpose. -
Another option would be to use Daemon Tools to create a virtual CD rom drive in which you can mount the image. Once the image is mounted, you can play it in your software player to check it before burning. This is nice because some downloaded bin/cue files aren't worth burning. To burn, simply use the disc to disc copying function of your CD mastering program to burn the mounted image. EZ CD, NTI, Nero, Clone CD, Blindwrite, DiscJuggler, etc. Daemon Tools is free and you can get it here: http://www.daemon-tools.com/daemon_tools.htm
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
