I'm a total noob when it comes to this. I've read through the forum, but it's making my head spin.
I'm making a compilation DVD of concert footage. The concert footage has been transferred from VHS and now each show is in a separate VIDEO_TS folder. These shows are short, maybe 20 minutes long, so I will have quite a few shows per disc.
What is the best way to go about putting these vide_ts folders into a DVD and then making a nice menu that would let you pick and choose concert dates. I'm good with Photoshop, so I want to make something cool in Photoshop and then use it for the menu.
If I need a separate program to make the menu, that is fine.
Also is there just a basic VHS clean up filter in AviSynth or VirtualDub? Also, some concerts are a little dark, would also like to brighten them up a bit if that's even possible.
Thanks. This all just seems a bit daunting never having done this before.
Start with AVStoDVD.
You will want to use the individual .vob files from your video_ts folders because a DVD can have only one video_ts folder. It has a fairly basic menu creator, but you can make your own backgrounds in photoshop.
If you don't insist on free software, check out TMPGenc Authoring Works or DVD Architect. -
for a 20 minute video, in 4:3 apsect, you are probably looking for ONE vob file from each folder
the largest vob file from the folder, possible less than 1 gig each, maybe only a few hundred megabytes
it might be a good idea copy and rename each vob with the name or date of the concert
when authoring your dvd use the renamed copied files
concert-1.vob
concert-2.vob
etc
as your source files for the dvd
you can check the vobs in the folder by playing each one with VLC aka video lan player it free , its very good, and it will play vobs
Where to start? I'm a amateur photographer and I want to start out in video
By James Wright in forum Newbie / General discussionsReplies: 14Last Post: 3rd Jul 2015, 14:12 -
New Camera and i don't know where to start
By Recusant in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 27th Jan 2013, 23:56 -
The Start button and the Windows taskbar don't appear on both display
By 1234567 in forum DVB / IPTVReplies: 12Last Post: 2nd Sep 2010, 10:39 -
Export HDV clips to SD clips from Premiere Pro CS3
By foochuck in forum EditingReplies: 10Last Post: 8th Jun 2010, 17:03 -
Custom Video Converstion Help 720p to custom 720p
By powerplyer in forum Video ConversionReplies: 5Last Post: 4th Jun 2009, 14:14
