Has anyone tried any of these programs and if so, whihc one would you recommend???
Ad Aware, it is freeware and one of the best, if not the best on the net. I have been using it and have had no problems with it apart from when I had Kazaa installed and it removed the spyware from it and then Kazaa didnt work but I solved that problem by blocking that item from being removed
Kazaa light is kazza hacked.
It has no spyware, only a dummy DLL that Kazaa thinks is spyware but it's nothing -
Yeh, I know about Kazaa Lite but this was ages ago that I used Kazaa(p2p is just fucked, mIRC is much better
), also I was using it as an example of what can happen to programs if you remove the spyware from it which really sucks if it is a good program
Batch remove privacy bit from mp3s?
By Lezleefeetsgoddess in forum AudioReplies: 13Last Post: 4th Jun 2012, 14:50 -
Internet, ISP and privacy
By smartel in forum Newbie / General discussionsReplies: 14Last Post: 26th Jan 2012, 00:08 -
Domain Privacy
By Sakuya in forum Off topicReplies: 0Last Post: 23rd Sep 2011, 02:13 -
Logs on my PC vs Privacy and Consent
By videobread in forum Newbie / General discussionsReplies: 9Last Post: 13th Nov 2007, 22:30 -
Kaspersky Internet Security 7.0 installation Conflicting with Internet Exp
By Krelmaneck in forum ComputerReplies: 2Last Post: 5th Oct 2007, 04:36
