how can i get VD to accept mp4 movies please
As manono suggests, if you just want to reprocess the audio it can be done with Audacity. But "mp4" is a container that can hold video made with many different encoders: h264, DivX, XVid, QuickTime, etc.. The file works in media players because either those players or your system has the proper codec somewhere. If you identify the codec there might be a way to open it in VirtualDub, but there are far more plugins available for opening it with Avisynth and running a script with VirtualDub.
Try the free MediaInfo utility, which will identify the video and audio codecs used.Last edited by sanlyn; 21st Mar 2014 at 14:33.
Audacity with the ffmpeg source plugin can import audio directly from your source file. After processing the audio save with the codec you want. Then use an MP4 muxing tool to mux your original video with your new audio.
VirtualDub with the right source plugins can open an MP4 file but you'll end up reencoding the video as well as the audio.
Virtual Dub MP4 No Audio Decompressor Could be Found
By shokan22 in forum Newbie / General discussionsReplies: 4Last Post: 25th Aug 2013, 10:54 -
Easy way to edit mp4 in virtual dub
By sparker3669 in forum EditingReplies: 31Last Post: 23rd Jan 2013, 08:08 -
Help with MP4 in Virtual Dub on Win7
By wynden in forum EditingReplies: 2Last Post: 27th Apr 2012, 02:28 -
Virtual Dub MP4 Plug In help
By Simmons in forum Video ConversionReplies: 2Last Post: 6th Jul 2011, 20:27 -
Can't edit MP4 files in Virtual Dub
By brevardo in forum EditingReplies: 25Last Post: 10th Mar 2011, 20:18
