When I perform a video conversion with ffmpeg and the output file already existing then the user is prompted if the existing video should be overwritten.
Can I somehow specify that the new (or old) video file is automatically renamed in this case?
e.g. to
<basevideoname>_<timestamp>.<extension>
or
<basevideoname>_new3.<extension>
Thank you
Peter
Not just with ffmpeg.
But if you use it together in a windows batch can you make something like http://stackoverflow.com/questions/17387072/using-command-prompt-batch-files-to-move-a...duplicate-file (the first answer). Instead of move you run the ffmpeg command with the new filename. -
How to Batch Convert with FFmpeg in Windows]http://backroom.bostonproductions.com/?p=378[/url] might also be worth a read
MeGUI and Automated 3pass - File exists?
By Asterra in forum Video ConversionReplies: 1Last Post: 26th Apr 2011, 19:35 -
need file rename tool
By sigpop in forum Video ConversionReplies: 2Last Post: 11th Feb 2011, 20:28 -
installation of ffmpegX (##mkdir: /usr/local/lib: File exists)
By carlos028 in forum ffmpegX general discussionReplies: 1Last Post: 19th Dec 2010, 20:57 -
Auto-GK file output, low quality despite large size
By Fallout1 in forum Newbie / General discussionsReplies: 10Last Post: 5th Oct 2009, 18:27 -
DVD menu exists in video ts folder but won't auto play upon insertion
By perceptionist in forum Authoring (DVD)Replies: 3Last Post: 2nd Aug 2009, 05:13
