Hello VH.com,
iam an audio engineer with a strong interest in Movie, Video, Animations & 3D.
I just got a really weird task, which iam not sure how to perform:
- iam getting SRTs
- integrate them into FCPX (iam using TitleExchange for that - works good)
- now the client wants me to export an XML (not fcpxml) with PNGs for all the Subtitles.
- So it should be one PNG for each subtitle (regardless the length of the Sub) and one XML for defining the timing of the PNGs - so the subtitles are not the written text but the respective PNG.
how can i do this? Iam on OSX 10.8.4 and FCPX 10.0.9. Also we have the newest Version of Submerge, in case this is any help.
thank you for your help.
KabeL
A Windows solution could be Subtitle Edit - File -> Export ...
I've got no Mac solution -
hey videobruger... thanks for your solution. i can make it work, since i have a windows application on the mac. do you know if there is a possibility to define font and position of the subtitle regarding to the hostvideo i want to create it to ? i know it sounds weird. but iam supposed to layer the Subs on the Video, so they look nice and have a good position. And THEN export them without the picture... but as seperated PNGs + a XML (which i could work out using the suggested program - not the fonts and position tho...)
thanks again,
Kabel -
When you choose export you'll be able to select font/size ...
The output is a .png for each subtitle and one .xml -
i see this but i have no control how the subs will look like if layered back on the clip again. Neither for the positioning. For instance - i'd like to put the sub into the black bar at the bottom of a video, in order to keep the visable part untouched. Can i have an influence on where the subs are positioned, or do i have to look for another tool - and if so, which one?
Depends on your player.i see this but i have no control how the subs will look like if layered back on the clip again
If you need further positioning besides those Subtitle Edit gives (left/center/right), ie vertical, you could try easySUP.Neither for the positioning -
well iam trying EZtitles IV right now - for my purpose its perfect.
Unfortunately the Full Version i need is like 2k and iam kinda looking for a less expensive solution.
Is belle-nuit providing the same options? I contacted belle-nuit for a demo version.
What you guys think about swift / annotation edit? -
Hola, Subtitle Edit supports these alignment in File -> Export -> image based format:
You set the alignment by right-clicking in the list view -> AlignmentCode:upper left upper center upper right center left center center right lower left lower center lower right
Also, font colors + italic are supported.
Convert XML to SRT subtitle file
By subsync in forum SubtitleReplies: 7Last Post: 15th Jun 2015, 17:08 -
BDN XML -> DoST format subtitle converter
By devilcoelhodog in forum SubtitleReplies: 0Last Post: 30th Jun 2013, 19:56 -
Inquiring about subtitle databases beyond the extract/export/dvd uses.
By vhelp in forum SubtitleReplies: 0Last Post: 22nd Oct 2009, 22:27 -
DVDAuthor XML subtitle pre command syntax
By Advocas in forum Authoring (DVD)Replies: 0Last Post: 29th Mar 2009, 12:51 -
editing PNGs in FCP
By whiff79 in forum MacReplies: 1Last Post: 3rd Jan 2009, 09:35
