Many Of us know that with DVD there is always a menu intro before the button highlights show up, I know in Scenarist There is Multiplexed & Non-multiplexed Always-on Menu options, I created 2 separate Menu Video's"01 - Top Menu (Menu Start)"
"02 - Top Menu (Menu IG Point)"
So I added the Multiplexed Always-on IG file to "02 - Top Menu (Menu IG Point)" and added it to the playlist where "01 - Top Menu (Menu Start)" is, and changed the connection_condition to Seamless, but it seems that it keeps telling me that the IG Stream Mismatches, and the other pain is that I want to make "02..." Loop as much as I want, but It Seems its Also going to continue crowding the "Scenario" window with the IG's (Which I expected that to happen)...
There is also the Non-Multiplexed Option which I used so often, but then again, non of the blu-rays I created had a menu Intro...
Is there anyway I can use the Non-multiplexed function and delay the time, or will I have to go the "hiccup" way to when it changed between playlists?
And also, Is there a risk where when the playlist changes between the intro and actual menu video, will there be a blackout in between?, Or will it continue without going back to change (of course with the same Resolution & Frame-rate)?
Thanks In Advance![]()
Results 1 to 1 of 1
Scenarist- return to specific menu button
By emotionboy in forum Authoring (Blu-ray)Replies: 2Last Post: 11th Feb 2012, 12:13 -
Scenarist 4.3 subtitles problem
By paulspurrier in forum Authoring (Blu-ray)Replies: 1Last Post: 11th Jun 2009, 07:16 -
Has anyone used Sonic Scenarist or DVDit pro HD?
By jbandy1 in forum Authoring (Blu-ray)Replies: 16Last Post: 18th Feb 2009, 02:08 -
error when import subtitle in scenarist
By pcb in forum SubtitleReplies: 4Last Post: 17th Feb 2009, 06:38 -
Scenarist Menus
By nx01rules in forum Authoring (DVD)Replies: 5Last Post: 11th Nov 2008, 01:22
